Using the example code from the Sipping Power with Neopixels Guide
Play with it! Please tell us which board you're using.
laffingskull
Post by laffingskull »
Hello!
I recently bought a Circuit Playground to test out some of the concepts from the Sipping Power With NeoPixels guide for a dotstar matrix project I will be working on. The provided code to use alongside the guide errors out when verifying the sketch.
I've attached the error log, I am not sure where to start with debugging this. Nothing has been done to modify the existing code here. I am very green with coding, I can follow concepts at surface level so you'll have to forgive me if the answer here is an obvious one. Thank you!
sketch_errors.txt
(140.6 KiB) Downloaded 11 times
Franklin97355
Re: Using the example code from the Sipping Power with Neopixels Guide
Post by Franklin97355 »
Make sure you have the latest software and libraries installed. I just tried to verify the code and was successful so you may have errors in your code. What board are you compiling this for?
// Sketch to accompany "Sipping Power With NeoPixels" guide. Designed for
// Adafruit Circuit Playground but could be adapted to other projects.
#include <Adafruit_CircuitPlayground.h>
laffingskull
I am compiling this for the Circuit Playground Classic. I just verified that I am on 1.8.19 of the IDE, and installed the latest cores for the Arduino boards too. I have the latest version of Adafruit_CircuitPlayground.h library installed. The demo code that comes with the Circuit Playground library works when compiled and uploaded. Would I be missing something? The code doesn't call for any other libraries. Debugging hard stops at "mode_off," as it was not declared in the scope.
laffingskull
I rebooted the IDE and reconnected everything after all those lib installs and updates. It is now working! Thank you!
Franklin97355
Great! Glad it worked and I was able to help you. Program on!
Return to “Circuit Playground Classic, Circuit Playground Express, Circuit Playground Bluefruit”
