Adafruit Ir break beam sensor help.
- AlexMaven
So I plan to combine two different sketches a stepper motor that rotates clockwise and counterclockwise when the ir break beam is broken. I figured first I need to figure out how to use the millis function because once the ir break beam is broken I want the sensor to be unbroken until 60,000 milliseconds. That's where I have a problem I don't know how to execute that , how to virtually turn off the sensor for 60 seconds. It currently works fine with the code given and is plugged into the the 3.3v power source on the arduino. Here's the code I'm using now https://learn.adafruit.com/ir-breakbeam-sensors/arduino
Re: Adafruit Ir break beam sensor help.
Take a look at the BlinkWithoutDelay example sketch:
https://www.arduino.cc/en/Tutorial/Buil ... thoutDelay
That shows how to handle event timing with millis().
The basic idea is to store the value millis() will have when it's time for the next event. If you want to wait for a minute, you save the current value of millis() plus 60,000 (now + 60 seconds)
