Help with project code?
Adafruit's tiny microcontroller platform. Please tell us which board you are using.
ScottieP
Post by ScottieP »
Howdy all,
I'm aiming to build a clock like this: https://learn.adafruit.com/trinket-powe ... clock/code and am trying to get the code on the Trinket, but keep getting errors that I don't understand. The error(s):
Arduino: 1.8.19 (Mac OS X), Board: "Arduino Uno" (I've tried this with several boards- is there one specifically for Trinkets?)
/Users/admin/Documents/Arduino/sketch_sep07a/sketch_sep07a.ino: In function 'void PWM4_init()':
sketch_sep07a:77:3: error: 'TCCR1' was not declared in this scope
TCCR1 = _BV (CS10); // no prescaler
/Users/admin/Documents/Arduino/sketch_sep07a/sketch_sep07a.ino:77:3: note: suggested alternative: 'TCCR1A'
TCCR1A
In file included from /Users/admin/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/avr/include/avr/io.h:99:0,
from /Users/admin/Library/Arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/avr/include/avr/pgmspace.h:90,
from /Users/admin/Library/Arduino15/packages/arduino/hardware/avr/1.8.5/cores/arduino/Arduino.h:28,
from sketch/sketch_sep07a.ino.cpp:1:
sketch_sep07a:78:31: error: 'PWM1B' was not declared in this scope
GTCCR = _BV (COM1B1) | _BV (PWM1B); // clear OC1B on compare
sketch_sep07a:80:3: error: 'OCR1C' was not declared in this scope
OCR1C = 255; // frequency
/Users/admin/Documents/Arduino/sketch_sep07a/sketch_sep07a.ino:80:3: note: suggested alternative: 'OCR1A'
OCR1A
exit status 1
These "not declared this scope" messages are stopping me cold. Can anyone help me make sense/get past this?
Thanks all,
Scott
Franklin97355
Re: Help with project code?
Post by Franklin97355 »
You need to select the Trinket:
ScottieP
Post by ScottieP »
Howdy Franklin,
Thank you! I'm looking at my boards manager and see that I have the SAMD and AVR boards installed, but not "Adafruit Boards". Is that in some special repository? Does it matter that I'm using Arduino 1.8.19, or that I'm on a Mac?
Cheers,
Scott
sj_remington
Post by sj_remington »
You need to go through the "getting started" tutorial with the Trinket, which includes installing the boards and drivers.
https://learn.adafruit.com/introducing-trinket
ScottieP
Post by ScottieP »
Update: I found https://github.com/arduino/Arduino/wiki ... pport-urls and the boards were there. I'm now able to verify. Thanks again Franklin!
Cheers,
Scott
Return to “Trinket ATTiny, Trinket M0”
