PWM shield use on Due
sekramer10
Post by sekramer10 »
I would like to use the PWM shield on a Due board. I see from the product page that Due is listed as compatible but there is no output on the shield. The shield works when I use it on a Mega2650 with the same sketch. I used the 3.3V VCC jumper and confirmed all the voltages were at 3.3V including the I2C pins on A4/A5 and the alternate pins above Aref. There is 0 volts on the PWM output pins regardless of the command given, which works fine on the Mega2650. Any help would be appreciated.
mikeysklar
Re: PWM shield use on Due
Post by mikeysklar »
Pretty much any board, but the DUE will work. The DUE has a i2c implementation that does not play well.
adafruit2
Post by adafruit2 »
you may need to address it as Wire1 - but really, we do not recommend the Due, it has a lot of I2C problems.
sekramer10
Thanks I got it working great with Wire1.
