#include <Arduino.h>
#define led 17
#define led1 19
#define button 14
unsigned long previousMillis = 0;
unsigned long prevMillis = 0;
const int interval = 500;
const int interval1 = 1000;
int ledState = LOW;
int ledState1 = LOW;
volatile bool buttonpresed = false;
void ledblink();
void ISR();
// put your setup code here, to run once:
Serial.begin(9600);
pinMode(led ,OUTPUT);
pinMode(button,INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(button),ISR,FALLING);
void loop()
// put your main code here, to run repeatedly:
int state = 0;
int sleeptime = 0;
while (1)
if (buttonpresed)
Serial.println("Button pressed");
int i = 0;
while (i < 10)
unsigned long currMillis = millis();
if (currMillis - prevMillis >= interval1)
i++;
prevMillis = currMillis;
// if the LED is off turn it on and vice-versa:
if (ledState1 == LOW)
ledState1 = HIGH;
else
ledState1 = LOW;
digitalWrite(led1, ledState1);
switch (state)
case 0:
for(int x =0;x<5;x++)
ledblink();
state = 1;
break;
case 1:
sleeptime = 0;
Serial.println("Button pressed1");
while (sleeptime < 10000)
__WFI();
sleeptime++;
Serial.println("Button pressed2");
state = 0;
break;
default:
break;
void ledblink()
digitalWrite(led, HIGH);
delay(500);
digitalWrite(led,LOW);
delay(500);
void ISR()
buttonpresed = true;
