Howdy all,
We have been playing around with the MLX90640 IR sensor and there is a weird
checkerboard artifact going on.
(I am not talking about the low resolution of the sensor).
but the hot-cold pixels that appear in a checkerboard pattern (e.g. bottom right corner).
Any idea if this is coming from the sensor array or from the code after the data capture?
MLX90640 IR Thermal Camera Checkerboard artifact
- aklianos
- Attachments
- Checkboad artifact issue- MLX90640.jpg (77.56 KiB) Viewed 652 times
- adafruit_support_mike
Re: MLX90640 IR Thermal Camera Checkerboard artifact
That's almost certainly an artifact of the code generating the image.
The text at the top of the image says it's using 'inter cubic' interpolation, which is most likely to be an uncommon name for bicubic interpolation.. a process that generates a smooth curve that passes through four points, calculated vertically and horizontally for each point in the original image.
Interpolation schemes have trouble generating good values for points that aren't directly in line with a value from the original image, and the image above looks like the algorithm is really struggling.
Try scaling the image up in multiple steps, increasing the resolution by a factor of 3 each time. Hopefully interpolating across a smaller distance will generatre enough good values to avoid the checkerboard effect.
- Disciple
A properly functioning MLX90640 can still show a checkerboard effect when the thermal scene before it changes. The sensor captures its pixels of thermal data in two passes, half the pixels update followed by the other half slightly later. An internal register can be changed to cause the two groups of pixels to update in either a checkerboard pattern or a horizontal stripes pattern. Either way, warm bodies in motion will cause a pattern to appear. Scaling up the pixels with higher order interpolation, they'll soften the sharp edges of the pattern to a degree, but it's a real part of the raw data.
Eliminating the pattern would take a bit of fancy work, like separating the pixels into two half images, then generating the missing pixels by averaging their neighbors to produce two full images to display... a fair task but possible. Hope this helps.
Hallelujah!
Disciple
Hallelujah!
Disciple
- sj_remington
By default, the sensor read out is interleaved checkerboard, in two passes, but I've rarely seen the effect shown in the image. As mentioned above, it can appear when the "hot spot" source is moving.
If the checkerboard pattern is consistent, that could be due to a defective sensor, or faulty code. Please post the raw sensor readings, in code tags, and the code as well.
- Sneha_Papineni
Howdy all,
PFA for the requested files. Also, the captured image below doesn't have any interpolation technique , which can be seen in the code (yet, the check board artifact is still visible)
sensor capture : Code : Raw temperature readings (which are temperature readings from right to left in the capture) : Also, can you please provide the emissivity information that is set in the sensor and Standard Procedure for calibrating the thermal sensor.
Thanks !
Thanks !
- sj_remington
The raw data definitely show a checkerboard pattern. You might try the Arduino C/C++ example code to see if there is a problem with python.
Raw data were processed by Matlab to produce a simple grayscale image.
data = csvread("mlx.csv");
datamin = min(data(1:24,1:32),[],'all');
datamax = max(data(1:24,1:32),[],'all');
I = mat2gray(data(1:24,1:32),[datamin datamax]);
imshow(I);
imwrite(I, 'image.png');
- Sneha_Papineni
Can you please share how to obtain the raw data of the sensor (i.e., not the apparent temperature value that is processed /calculated and given as output) ?
Thank you
Thank you
Also try splitting out the even rows and even columns, assuming the row/column values start at 1.. if the numbers start at 0 get an image that contains the odd rows and columns.
It looks like a lot of those pixels have the same value.
- Sneha_Papineni
Howdy !
PFA for the images after splitting the even columns and rows (i.e., reduced the resolution to 12*16 from 24*32) and the original image.
The new / less resolution image is better in terms of minimal to no checkerboard artifacts. Yet, it has very poor resolution due to which it is difficult to get true temperature values at a specified target. How could we solve this problem and get a decent capture with 24*32 pixels resolution and without this check-board artifacts.
Thank you and looking forward to hear from you
Try extracting the other complementary images:
- even rows, odd columns
- odd rows, even columns
- odd rows, odd columns
The large image looks like one of those groups has much lower variation than the others.
- Sneha_Papineni
Howdy!
The maximum frame rate that I could get for capturing thermal images is 2 Frames per second. Yet, to get the raw temperature data using the attached code, the frame rate dropped to 1 frame per second. Why is that so ?
Can you please share if there is any other code/ way to get the the raw temperature data at a faster frame rate?
import time
import board
import busio
import adafruit_mlx90640
i2c = busio.I2C(board.SCL, board.SDA, frequency=800000)
mlx = adafruit_mlx90640.MLX90640(i2c)
print("MLX addr detected on I2C", [hex(i) for i in mlx.serial_number])
mlx.refresh_rate = adafruit_mlx90640.RefreshRate.REFRESH_2_HZ
frame = [0] * 768
while True:
try:
mlx.getFrame(frame)
except ValueError:
continue
for h in range(24):
for w in range(32):
t = frame[h*32 + w]
print("%0.1f, " % t, end="")
print()
print()
import time
import board
import busio
frame = [0] * 768
while True:
try:
mlx.getFrame(frame)
except ValueError:
continue
for h in range(24):
for w in range(32):
t = frame[h*32 + w]
print()
print()
- Sneha_Papineni
Howdy!
I am writing this regarding the faulty mlx90640 thermal sensor we received. PFA for a thermal capture of a close up shot of hot water (inside a cup/mug) which is around (76 degrees Celsius - measured using a K-type thermocouple at the centre of the frame).
Also, find the raw temperature values of the capture. From the values you can see the extreme variations of the temperature values of each pixel (whereas, ideally they should be more or less ,the same). Such huge deviations (Max temp. pixel - min temp. ~ 10 degrees difference) despite the error - max.temp. - thermocouple temp (~3 degrees celsius), Such high discrepancies are not accepted for the research purpose. We need another sensor in compensation for the faulty one. We will return the current sensor once you sent the new sensor.
It has almost been two months since we started bothering you regarding these faulty results/checkerboard patterns. Moreover, we haven't yet received any satisfactory reply and thus is not expected from your company. Kindly treat this on high priority and send us a new non-faulty thermal sensor.
Sincerely,
Sneha Papineni
Sincerely,
Sneha Papineni
I haven't seen even similar behavior from any MLX90640, and the information from the debugging is inconclusive.
We'll do a replacement, but if the second one shows the same kind of behavior we'll have to assume it's related to conditions in the operating environment. Send a note containing a link to this page and your order number to [email protected]. The folks there will get you a replacement.
- Sneha_Papineni
Howdy!
Thank you very much for your support and understanding. I have mailed the requested details to [email protected]
Please let me know if anything else is required from for the timely replacement.
Thanks and regards,
Sneha Papineni
Thanks and regards,
Sneha Papineni
