The Adc from the Pico direct recognize the value from 65535 steps.
The Adc from the ADS1115 recognize only the half 32767 steps.
Have i maybe a mapping Problem ?
Thanks for Help!
Code:
import board
import busio
import time
import digitalio
import usb_hid
import analogio
#-----analog setup-----
i2c = busio.I2C(board.GP1, board.GP0)
import adafruit_ads1x15.ads1115 as ADS
from adafruit_ads1x15.analog_in import AnalogIn
ads = ADS.ADS1115(i2c)
#-----joystick setup-----
from adafruit_hid.gamepad import Gamepad
gp = Gamepad (usb_hid.devices)
button_pins = (board.GP10, board.GP11, board.GP12, board.GP13, board.GP14, board.GP15)
gamepad_buttons = (1, 2, 3, 11, 12, 13)
buttons = [digitalio.DigitalInOut(pin) for pin in button_pins]
for button in buttons:
button.direction = digitalio.Direction.INPUT
button.pull= digitalio.Pull.UP
ads.gain = 4
ay = AnalogIn(ads, ADS.P0)
ax = analogio.AnalogIn(board.A1)
#az = analogio.AnalogIn(board.A2)
#ar_z = analogio.AnalogIn(ads, ADS.P2)
#az = analogio.AnalogIn(ads, ADS.P3)
def range_map(x, in_min, in_max, out_min, out_max):
return (x - in_min) * (out_max - out_min) // (in_max - in_min) + out_min
while True:
for i, button in enumerate(buttons):
gamepad_button_num = gamepad_buttons[i]
if button.value:
gp.release_buttons(gamepad_button_num)
else:
gp.press_buttons(gamepad_button_num)
print(ay.value)
time.sleep(1)
gp.move_joysticks(
x=range_map(ax.value, 0, 65535, -127, 127),
y=range_map(ay.value, 0, 65535, -127, 127),
# r_z=range_map(ar_z.value, 0, 65535, -127, 127),
# z=range_map(az.value, 0, 65535, -127, 127),
