RP2040 Feather and Adafruit I2C Stemma QT Rotary Encoder
- hvrper000
I have a I2C Stemma QT Rotary Encoder connected to the I2C port on the Feather RP2040 Pico. I am essentially using the sample code that is on the Adafruit I2C Rotary Encoder page and am having trouble with missed steps. In fact most of the steps get missed. For now I am just trying to print the step movement to the screen in Thonny but I cant get the steps to get picked up consistently. Does anyone have any ideas why this doesn't work consistently and how i can fix it? Thank you.
- Attachments
- code.py-rotary encoder.py
- (1.9 KiB) Downloaded 3 times
- adafruit_support_carter
Re: RP2040 Feather and Adafruit I2C Stemma QT Rotary Encoder
Try the simpletest example and see if it behaves the same way:
https://github.com/adafruit/Adafruit_Ci ... pletest.py
Also, should be able to use the built in board.STEMMA_I2C() bus when setting up seesaw, ex:
seesaw = seesaw.Seesaw(board.STEMMA_I2C(), 0x36)
- hvrper000
That code works perfectly. Thank you for the help.
- hvrper000
I spoke too soon. It worked at first and then the issue returned. I swapped out the rotary encoder and the new one worked perfectly. I went to pull the knob off the other rotary encoder before tossing it in the trash and the whole encoder pulled up. I did not realize that I had only pushed the pieces together and had not soldered them. Sorry for that. However I do appreciate the additional recommendation about the I2C port.
