LC709203F with 12ah Battery
kevinv2
Post by kevinv2 »
Hi im using the LC709203F with 12ah Battery (12000MHA) LiFePO4 Battery, on the setup page it says:
Pick the closest of the following values for your battery size:
LC709203F_APA_100MAH,
LC709203F_APA_200MAH,
LC709203F_APA_500MAH,
LC709203F_APA_1000MAH,
LC709203F_APA_2000MAH,
LC709203F_APA_3000MAH,
Do i pick LC709203F_APA_3000MAH? it's nowhere close to the actual battery size
thanks
adafruit_support_mike
Re: LC709203F with 12ah Battery
Use the largest setting, then track any difference between the sensor's output and the actual battery condition.
The fact that there are multiple settings implies different behavior as the storage capacity of the battery increases.
mangocats
Post by mangocats »
Somewhat related, I'm using the pid4712 with one of your 6600mAh lipo packs... I went to look up the LC709203F but all I could find was a LC709204F datasheet. In there, they list support for battery types up to 6000mAh with codes that differ a bit from your Circuit Python definitions for the 203....
Is the LC709204F significantly different from the LC709203F? If so, where might we find a LC709203F datasheet?
There's a datasheet linked from nthe Downloads page of the LC709203F tutorial:
https://learn.adafruit.com/adafruit-lc7 ... /downloads
https://cdn-learn.adafruit.com/assets/a ... 1599248750
mangocats
Post by mangocats »
Thanks. Definitely a different part.
