VL53L0X ToF sensor - Low memory problem
lyehezkel
Post by lyehezkel »
hi
Im using 3 VL53L0X sensors with the arduino uno R3, and the code that i use is the following:
#include "Adafruit_VL53L0X.h"
// address we will assign for all 4 sensor
#define LOX1_ADDRESS 0x30
#define LOX2_ADDRESS 0x31
#define LOX3_ADDRESS 0x32
// set the pins to shutdown for all 4 sensors
#define SHT_LOX1 2
#define SHT_LOX2 3
#define SHT_LOX3 4
// objects for the vl53l0x
Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
Adafruit_VL53L0X lox3 = Adafruit_VL53L0X();
void setID() {
  //Serial.print(F("brake 1, "));
  // all unreset
  digitalWrite(SHT_LOX1, HIGH);
  digitalWrite(SHT_LOX2, HIGH);
  digitalWrite(SHT_LOX3, HIGH);
  delay(10);
  //Serial.print(F("brake 2, "));
  // activating LOX1 and reseting LOX2,LOX3
  digitalWrite(SHT_LOX2, LOW);
  digitalWrite(SHT_LOX3, LOW);
  delay(10);
  Serial.print(F("brake 3, "));
  delay(1000);
  // initing LOX1
  if(!lox1.begin(LOX1_ADDRESS)) {
    Serial.print(F("brake 3.1, "));
    Serial.println(F("Failed to boot first VL53L0X"));
    delay(500);
    while(1);
  delay(10);
  Serial.print(F("brake 4, "));
  ///************************* sensor 2 activation
  // activating LOX2
  delay(10);
  Serial.print(F("brake 5, "));
  //initing LOX2
  if(!lox2.begin(LOX2_ADDRESS)) {
    Serial.println(F("Failed to boot second VL53L0X"));
    while(1);
  delay(10);
  Serial.print(F("brake 6, "));
   ///************************* sensor3 activation
  // activating LOX3
  delay(10);
  //initing LOX3
  if(!lox3.begin(LOX3_ADDRESS)) {
    while(1);
void read_quad_sensors() {
  // this holds the measurement
  VL53L0X_RangingMeasurementData_t measure1;
  VL53L0X_RangingMeasurementData_t measure2;
  VL53L0X_RangingMeasurementData_t measure3;
  int sensor1,sensor2,sensor3;
  lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
  lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
  lox3.rangingTest(&measure3, false); // pass in 'true' to get debug data printout!
  // print sensor one reading
  Serial.print(F("1: "));
  if(measure1.RangeStatus != 4) {     // if not out of range
    sensor1 = measure1.RangeMilliMeter;
    Serial.print(sensor1);
    Serial.print(F("mm"));
  } else {
    Serial.print(F("Out of range"));
  Serial.print(F(" "));
  // print sensor two reading
  Serial.print(F("2: "));
  if(measure2.RangeStatus != 4) {
    sensor2 = measure2.RangeMilliMeter;
    Serial.print(sensor2);
  } else {
  Serial.print(F("3: "));
  if(measure3.RangeStatus != 4) {
    sensor3 = measure3.RangeMilliMeter;
    Serial.print(sensor3);
  } else {
  Serial.println();
  Serial.begin(115200);
  // wait until serial port opens for native USB devices
  while (! Serial) { delay(1); }
  pinMode(SHT_LOX1, OUTPUT);
  pinMode(SHT_LOX2, OUTPUT);
  pinMode(SHT_LOX3, OUTPUT);
  Serial.print(F("Shutdown pins inited..."));
  digitalWrite(SHT_LOX1, LOW);
  Serial.print(F("All three in reset mode...(pins are low) "));
  Serial.println("Starting...");
  setID();
  read_quad_sensors();
  delay(100);
the global memory is nearly at his maximum (99%). and i have tried to use this code without setID() and got to 81% use of global memory.
my problem is that when im using 2 sensors it works just fine. and when im using 3 sensors it doesnt print "brake 4" or even "brake 3.1" and starting the setup all over again.
i would much appreciate if someone can please help me.
and i would to thank Robojax.com for the template of this code
Reason: Add code tags
dastels
Re: VL53L0X ToF sensor - Low memory problem
Post by dastels »
It would appear that you don't have enough RAM to do the required dynamic allocations. The ATmega328 on the UNO only has 2K of RAM. I suggest you upgrade to something more capable. I.e. something with more RAM. If you want to keep the UNO footprint, one of the Metro boards would be a natural upgrade...just not one of the "328" models. The Metro M0 Express would be a good choice https://www.adafruit.com/product/3505. The code would work as-is.
