BNO055 - STEMMA QT / Qwiic - No pull up found on SDA or SCL; check your wiring
jdubrow
Post by jdubrow »
I have a https://www.adafruit.com/product/4646, and I tried using the example from: https://learn.adafruit.com/adafruit-bno ... cuitpython. When I try running it returns the following error. I also have a sht31d connected via STEMMA QT connectors. I tried with just the BNO055 and it still gave the same error, but occasionally had the second error shown.
First (primary error):
Hello World!
File "code.py", line 13, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
Second error:
File "code.py", line 15, in <module>
File "/lib/adafruit_bno055.py", line 777, in __init__
File "/lib/adafruit_bno055.py", line 212, in __init__
File "/lib/adafruit_bno055.py", line 788, in _read_register
Code:
import board
import digitalio
import time
import busio
import adafruit_sht31d
import adafruit_bno055
print("Hello World!")
led = digitalio.DigitalInOut(board.LED)
led.direction = digitalio.Direction.OUTPUT
i2c = busio.I2C(board.SCL, board.SDA) # <=- line 13
sensor = adafruit_sht31d.SHT31D(i2c)
sensor2 = adafruit_bno055.BNO055_I2C(i2c)
jdubrow
Re: BNO055 - STEMMA QT / Qwiic - No pull up found on SDA or SCL; check your wiring
Post by jdubrow »
The sht31d works fine if python just uses that device, both with and without the BNO055 connected.
jdubrow
Post by jdubrow »
Also, I'm using this feather: https://www.adafruit.com/product/5477
Franklin97355
Post by Franklin97355 »
There are pullup resistors on the board. Can you post pictures of the board so we can check?
jdubrow
Post by jdubrow »
Here is a snapshot of the board.
gammaburst
Post by gammaburst »
Try this experiment:
Temporarily attach a short bare wire (a few centimeters) to signal SCL.
Grab the bare wire with two fingers, reboot the project, and observe its behavior.
Does the project run better, worse, or about the same?
Your fingers add some capacitance that slows the signal's risetime.
jdubrow
Post by jdubrow »
gammaburst wrote: Mon Sep 19, 2022 5:00 pm Try this experiment:
Tried that without any luck. My multimeter shows 3.3v on SDA/SCL when not running any code. Only having issues with the BNO055. Two other devices work without a problem.
/Jason
gammaburst
Hi jdubrow,
I ordered a couple Adafruit 5477 boards. Should arrive Wednesday. I'll try to reproduce your error message.
In the mean time, here's an example of a successful finger-grab test:
viewtopic.php?p=889280#p889280
(That's discussing a BNO085, but it has the same I2C timing problem as the BNO055.)
Of course, your board may have a completely different problem.
jdubrow
Post by jdubrow »
I tried adding a 2.8k resistor between Vin and SDA. It did not help. I then tried SCL also without luck.
gammaburst
Hi jdubrow, I received the ESP32-S3 and connected it to a SHT31D and BNO055. I see two CircuitPython problems, maybe in the busio library:
- CircuitPython fails to clear the I2C bus (by outputting some dummy SCL cycles) when starting up. If a slave is holding SDA low, it emits the misleading "no pullup found" error message.
- CircuitPython times out during the BNO055's clock-stretching I2C cycle. That causes an "ETIMEDOUT" error message. I think you saw timeout errors too, but your earlier message (mentioning lines 777 212 788) didn't include the full error message. I tried changing the timeout value but it's either broken or poorly documented. I recall seeing this problem before, and I think I fixed it by switching from CircuitPython 8 to 7, but version 7 isn't available for the ESP32-S3.
The extra pullup resistor on SCL is probably needed too.
Other folks have encountered these same problems, but Adafruit seems uninterested in fixing them.
jdubrow
Post by jdubrow »
gammaburst wrote: Wed Sep 21, 2022 10:42 pm ....
Ahhh that would explain why it thinks it had no pull up :)
Yes, that was one of the errors I received, though it only happened one time and I'm not even sure how I ended up causing it to occur and haven't been able to repeat it beyond the one time it failed with the timeout.
That stinks that they aren't willing to stand by the products and fix them. :( I'd never used circuit python before but thought it would be good to brush up on my python. Maybe I'll just go back to C. Where in the code is the problem? Is it in the adafruit library or some central part of circuit python?
/Jason
gammaburst
CircuitPython is based upon MicroPython, so CircuitPython probably inherits its I2C bugs. I vaguely recall seeing similar bug reports in MicroPython forums. I don't know how to fix CircuitPython/MicroPython. I'm no Python developer. I'm maybe one step above a Python newbie. I normally use C.
The I2C bus clearing step is described in the I2C specification. See section 3.1.16: https://www.nxp.com/docs/en/user-guide/UM10204.pdf
I can read the SHD31D by using busio but not bitbangio.
I can read the BNO055 by using bitbangio but not busio.
I haven't found one way to read both sensors.
Here's my test code:
import board
import digitalio
import time
print("\n\n***** Hello world *****")
if True:        # optionally wiggle SCL to clear I2C slave devices
  print("***** Clear I2C bus *****")
  scl = digitalio.DigitalInOut(board.SCL)
  scl.direction = digitalio.Direction.OUTPUT  # want open drain scl.drive_mode = digitalio.DriveMode.OPEN_DRAIN
  for n in range(1,20):
    scl.value = 0
    time.sleep(0.0001)
    scl.value = 1
    time.sleep(0.0001)
  scl.direction = digitalio.Direction.INPUT
  scl.deinit()
for k in range (2):
  print("***** Hello SHT31D *****")
  import busio
  i2c = busio.I2C(board.SCL, board.SDA, frequency=100000, timeout=10000)
  sht31d = adafruit_sht31d.SHT31D(i2c)
  for n in range (10):
    time.sleep(0.1)
    print("Temperature: {:+7.2f}".format(sht31d.temperature))
  i2c.deinit()
  print("***** Goodbye SHT31D *****")
  print("***** Hello BNO055 *****")
  import bitbangio
  i2c = bitbangio.I2C(board.SCL, board.SDA, frequency=100000, timeout=10000)
  bno055 = adafruit_bno055.BNO055_I2C(i2c)
    time.sleep(0.1)
    print("Quaternion: {:+8.5f} {:+8.5f} {:+8.5f} {:+8.5f}".format(*bno055.quaternion))
  i2c.deinit()
  print("***** Goodbye BNO055 *****")
print("***** Goodbye cruel world *****\n")
jdubrow
Post by jdubrow »
Thanks! That code does work!
