Celsius to Fahrenheit
adafruit.io wippersnapper BETA support, discussions, and more!
Post Reply
TheGodmothersGarden
Post by TheGodmothersGarden »
Is there a wat to make the components like the aht20 work in F not Celsius. It kind of of makes it useless because i have to look up the conversions every time.
I feel like most of the users of adafruit io are in the States. Would really love to see an option or at least have it be F by default.
dastels
Re: Celsius to Fahrenheit
Post by dastels »
You can always wrap the AHTx0 class's temperature method with something that converts C to F.
As for making F the default... most of the world uses metric so C is a sensible default. And the sensor reports temperature in C.
I'm not seeing the connection between the sensory library and Adafruit IO. And I don't see anything in Adafruit IO that specifically mentions units.
brubell
Post by brubell »
Hi, thanks for the feedback. We have an open issue for adding conversions to the WipperSnapper Beta firmware.
TheGodmothersGarden
Any luck with adding this to the next firmware update I use this very often and it would be amazing if it’s not to hard for you guys to do. Please and thank you 🙏
brubell
Post by brubell »
TheGodmothersGarden wrote: Wed Sep 21, 2022 6:17 am Any luck with adding this to the next firmware update I use this very often and it would be amazing if it’s not to hard for you guys to do. Please and thank you 🙏
We discussed this last week and merged in a solution.(https://github.com/adafruit/Wippersnapp ... 06cfafefef).
For devices with a temperature sensor, we'll present component options for enabling a temperature sensor to report data either degC or degF.
It's not live yet, but it'll be in an upcoming firmware release, we'll blog about it when it's up :)
whmckinley
Post by whmckinley »
Can't wait for it to go live, Got about 15 of these I'll need to deploy for family.
AHT20 with ESP32-S3 qty
brubell
Post by brubell »
This is LIVE, you must be using Beta.51 or later!
https://github.com/adafruit/Adafruit_Wi ... .0-beta.51
whmckinley
At the time I programmed the module, it wasn't. But the new ones I'm building are configurable for Fahrenheit. Prototype is already cross country. Just started the builds. Have to order 13 more esp32's.
Thanks For The Update
brubell
Post by brubell »
You could instruct them/point them towards our documentation on how to update the WipperSnapper version running on the Qt PY ESP32-S3.
TI545
Post by TI545 »
brubell wrote: Wed Sep 28, 2022 4:11 pm This is LIVE, you must be using Beta.51 or later!
I gotta say, that new step-by-step update-your-board feature in wippersnapper is nice. I needed to update my esp32-s2 qtpy from beta 31, and beta 51 was there. I had been jumping back to learn.adafruit each time to get the steps right. Thanks.
Post Reply
Return to “Adafruit IO Wippersnapper Beta”
