I'm using a BNO085 with a Jetson Nano and need to get the orientation as quaternion. Therefore, I use this code (see below). What I need is an absolute vector but each time I run my code, it starts with 0 at the actual orientation. So when I face to east and start, it reports 0 for east. When I shut down and move my robot facing north and start again, my program reports 0 for north. So I get a relative yaw value but I need absolute value
What do I need to change to get a 0 on east always?
To test this, I use this ROS code to get quaternion. I feed this into another node, which translates the quaternion into euler angles (see second code), which returns the yaw value in radians.
EDIT: Instead of reading quaternion from rotation vector, I changed the code to use geomagnetic vector. now I get the same values each time. But to my understanding, geomagnetic vector should be less accurate than rotation vector and rotation vector takes magnetometer into account as well. So I wonder, why rotation vector acts like game vector.
EDIT EDIT: but the geomagnetic_quaternion is not normalized, so it is invalid and looks different to the other
#!/usr/bin/env python3
# Driver: SPDX-FileCopyrightText: 2020 Bryan Siepert, written for Adafruit Industries
import rospy
from sensor_msgs.msg import MagneticField,Imu
from std_msgs.msg import Float64
from diagnostic_msgs.msg import DiagnosticStatus
import time
import sys
import board
import busio
from adafruit_bno08x import (
BNO_REPORT_ACCELEROMETER,
BNO_REPORT_GYROSCOPE,
BNO_REPORT_MAGNETOMETER,
BNO_REPORT_ROTATION_VECTOR,
BNO_REPORT_GYRO_INTEGRATED_ROTATION_VECTOR,
BNO_REPORT_GEOMAGNETIC_ROTATION_VECTOR
from adafruit_bno08x.i2c import BNO08X_I2C
def bno08x_node():
# Initialize ROS node
raw_pub = rospy.Publisher('bno08x/raw', Imu, queue_size=10)
mag_pub = rospy.Publisher('bno08x/mag', MagneticField, queue_size=10)
status_pub = rospy.Publisher('bno08x/status', DiagnosticStatus, queue_size=10)
rospy.init_node('bno08x')
rate = rospy.Rate(100) # frequency in Hz
rospy.loginfo(rospy.get_caller_id() + " bno08x node launched.")
frame_id = rospy.get_param('~frame_id', 'imu')
# load covariance from parameter
cov_linear = rospy.get_param('~cov_linear', -1)
cov_angular = rospy.get_param('~cov_angular', -1)
cov_orientation = rospy.get_param('~cov_orientation', -1)
cov_magnetic = rospy.get_param('~cov_magnetic', -1)
i2c = busio.I2C(board.SCL, board.SDA, frequency=800000)
bno = BNO08X_I2C(i2c,address=0x4a) # BNO080 (0x4b) BNO085 (0x4a)
bno.enable_feature(BNO_REPORT_ACCELEROMETER)
bno.enable_feature(BNO_REPORT_GYROSCOPE)
bno.enable_feature(BNO_REPORT_MAGNETOMETER)
bno.enable_feature(BNO_REPORT_ROTATION_VECTOR)
#bno.enable_feature(BNO_REPORT_GEOMAGNETIC_ROTATION_VECTOR)
time.sleep(0.5) # ensure IMU is initialized
while not rospy.is_shutdown():
raw_msg = Imu()
raw_msg.header.stamp = rospy.Time.now()
raw_msg.header.frame_id = frame_id
accel_x, accel_y, accel_z = bno.acceleration
raw_msg.linear_acceleration.x = accel_x
raw_msg.linear_acceleration.y = accel_y
raw_msg.linear_acceleration.z = accel_z
gyro_x, gyro_y, gyro_z = bno.gyro
raw_msg.angular_velocity.x = gyro_x
raw_msg.angular_velocity.y = gyro_y
raw_msg.angular_velocity.z = gyro_z
quat_i, quat_j, quat_k, quat_real = bno.quaternion
raw_msg.orientation.w = quat_real
raw_msg.orientation.x = quat_i
raw_msg.orientation.y = quat_j
raw_msg.orientation.z = quat_k
raw_msg.orientation_covariance[0] = -1
raw_msg.linear_acceleration_covariance[0] = -1
raw_msg.angular_velocity_covariance[0] = -1
if cov_orientation != -1:
raw_msg.orientation_covariance[0] = cov_orientation
raw_msg.orientation_covariance[4] = cov_orientation
raw_msg.orientation_covariance[8] = cov_orientation
if cov_linear != -1:
raw_msg.linear_acceleration_covariance[0] = cov_linear
raw_msg.linear_acceleration_covariance[4] = cov_linear
raw_msg.linear_acceleration_covariance[8] = cov_linear
if cov_angular != -1:
raw_msg.angular_velocity_covariance[0] = cov_angular
raw_msg.angular_velocity_covariance[4] = cov_angular
raw_msg.angular_velocity_covariance[8] = cov_angular
raw_pub.publish(raw_msg)
mag_msg = MagneticField()
mag_x, mag_y, mag_z = bno.magnetic
mag_msg.header.stamp = rospy.Time.now()
mag_msg.magnetic_field.x = mag_x
mag_msg.magnetic_field.y = mag_y
mag_msg.magnetic_field.z = mag_z
mag_msg.magnetic_field_covariance[0] = -1
if cov_magnetic != -1:
mag_msg.magnetic_field_covariance[0] = cov_magnetic
mag_msg.magnetic_field_covariance[4] = cov_magnetic
mag_msg.magnetic_field_covariance[8] = cov_magnetic
mag_pub.publish(mag_msg)
status_msg = DiagnosticStatus()
status_msg.level = 0
status_msg.name = "bno08x IMU"
status_msg.message = ""
status_pub.publish(status_msg)
rate.sleep()
rospy.loginfo(rospy.get_caller_id() + " bno08x node finished")
if __name__ == '__main__':
try:
bno08x_node()
except rospy.ROSInterruptException:
rospy.loginfo(rospy.get_caller_id() + " bno08x node exited with exception.")
import rospy
from sensor_msgs.msg import Imu
from tf.transformations import euler_from_quaternion, quaternion_from_euler
def get_rotation (msg):
global roll, pitch, yaw
orientation_q = msg.orientation
orientation_list = [orientation_q.x, orientation_q.y, orientation_q.z, orientation_q.w]
(roll, pitch, yaw) = euler_from_quaternion (orientation_list)
print yaw
rospy.init_node('my_quaternion_to_euler')
sub = rospy.Subscriber ('/bno08x/raw', Imu, get_rotation)
r = rospy.Rate(1)
r.sleep()
