FunHouse - edit the onboard code
- ADA_sgf1960
How do i stop the automatic code so that I can edit and upload my own?
- dastels
Re: FunHouse - edit the onboard code
If you intend to use C++ (using Arduino or other environments) you can just "upload" (i.e. reflash) your code onto the board.
If you plan to use CircuitPython (https://learn.adafruit.com/welcome-to-circuitpython) you can install it if it isn't already on the board then (or just, if it's already installed) copy your code.py et.al. to the CIRCUITPY drive that the board provides.
