The LED 7 segment display backpack has 2mm diameter holes for mounting. Is there a particular recommended bolt size for these? I don't believe an M2 would fit, and 2-56 definitely don't (they work with all the other Adafruit boards I have been using).
Thanks,
Allan.
Recommended bolt size for 7 Segment Backpack 2mm holes
- ayates
Re: Recommended bolt size for 7 Segment Backpack 2mm holes
Our standard mounting hole size is 0.100". M2.5 bolts should work.
