Can you interface a Adafruit Stepper + DC Motor FeatherWing with Adafruit METRO 328?
If so what will the schematic look like. Thanks for the assistance
- adafruit_support_bill
Re: Stepper + DC Motor FeatherWing
Yes, it is possible to connect via jumpers. Although a better match is the Motor Shield which is the same circuit - but configured to plug directly into the Metro 328 (and other boards with the classic Arduino header configuration)
https://www.adafruit.com/product/1438
To connect the Wing to the Metro, you would need to connect GND to GND. And since the Metro is a 5v processor, you would connect 5v from the Metro to 3.3v on the Wing to power the logic circuitry. https://learn.adafruit.com/adafruit-ste ... ns-1883525
For communication, connect SDA to SDA and SCL to SCL: https://learn.adafruit.com/adafruit-ste ... ns-1883528
Motor power is separate from the logic power and will depend on the motors you are using: https://learn.adafruit.com/adafruit-ste ... ns-1883518
- RickyRivits
Thanks for the tip, My Metro has 3v output buss too. So I am using it. Still struggling with software. Can't find two libraries adafruit_pca9685 and adafruit_motorkit. So Im sunk with getting anything accomplished today.
But it has a 5v signal levesl, so you need to use 5v for the Wing to avoid damage.My Metro has 3v output buss too. So I am using it.
The Motorkit library is for Python and is not applicable to the Metro 328. You need the Adafruit Motor Shield library linked in the guide:Still struggling with software. Can't find two libraries adafruit_pca9685 and adafruit_motorkit.
https://learn.adafruit.com/adafruit-ste ... ry-1883554
- RickyRivits
Thanks, Threw in the towel...just purchased the V2 shield.
