OSError: /dev/spidev0.0 does not exist
ls /dev/spi*
ls: cannot access '/dev/spi*': No such file or directory
Does the kernel module in the tutorial below block the entire SPI bus? If so, is there another SPI bus I could use to interface with sensors? Or is there another way to get the console on the display without blocking the SPI bus?
https://learn.adafruit.com/adafruit-min ... le-install
