Is there an Adafruit device that can externally control USB power, ideally from Raspberry Pi 4 ? I am thinking about a project to turn on/off a fan that is USB powered, based on temperature data.
Perhaps there is something like a STEMMA QT connected gadget that has USB port and can control USB power ?
Other ideas are welcome too.
a way to control USB power ?
- mikeysklar
Re: a way to control USB power ?
You can toggle power to the USB ports using uhubctrl.
There are more elegant ways to control the fan like using a PWM based 3-pin unit. Pi OS has fan control based on temperature built-in.
There are also more DIY options such as using the EMC2101 i2c PC fan setup:
https://www.adafruit.com/product/4808
- vladak
Thanks for the reply. These are fine ideas, esp. the fan control via STEMMA QT connected board.mikeysklar wrote: ↑Tue Sep 06, 2022 8:39 pm You can toggle power to the USB ports using uhubctrl.
In the end I went with a classic solution by using TP-link P110 smart plug controlled from Python code (via https://github.com/fishbigger/TapoP100/). The downside is that it control just on/off but not fan speed so in the future I might try the PWM board.
