Hello! Following instructions https://learn.adafruit.com/building-cir ... cuitpython, everything goes fine until the very last step and that is copying firmware.uf2 to /Volumes/MATRIXBOOT (This is on macOS) After this, the board reboots as expected, but CIRCUITPY never gets mounted. Installing the prebuilt firmware from https://circuitpython.org/board/matrixportal_m4 works fine. I tried pulling the latest TOT and various tags of circuitpython, including 7.3.3 - all with the same result.
How would I troubleshoot this issue? Thanks!
Building cirtcuitpython for MatrixPortal M4
- dougiejones
- dastels
Re: Building cirtcuitpython for MatrixPortal M4
You built with BOARD=matrixportal_m4 ?
- dougiejones
Affirmative.
- dastels
I'm asking around to get some eyes on this.
- dougiejones
Thank you. I tried uploading my built firmware, but seems like you can only attach images here ¯\_(ツ)_/¯
- danhalbert
You can upload a .zip of the .uf2. But did you make any changes to the original source tree before you built? If so, you can push your changes to a branch on your repo and we can take a look at that.
- dougiejones
No - no changes at all! zip attached.
Thanks!- tannewt
Did you get this working?
