0.91" OLED doesn't show in I2C Scan, but green power LED comes on
ChrisElectron
Post by ChrisElectron »
Issue:
When trying to run the OLED sample code, nothing shows on the display, but the green power LED comes on.
Trying to run the I2C_Scan.ino sketch doesn't find a connected device.
Hardware:
0.91" OLED
ESP32-S2 QTPY
STEMMA Cable
Software:
Arduino IDE v2
Adafruit Testbed library
The problem showed up when trying to run the sample code for the OLED.
Output from I2C_Scan.ino
Default port (Wire) I2C scan:
Secondary port (Wire1) I2C scan: 0x3C,
Green power LED lights up
IMG_3865 (Medium).jpeg (341.27 KiB) Viewed 72 times
Nothing on display even though sample script is outputting to serial
IMG_3864 (Medium).jpeg (335.75 KiB) Viewed 72 times
dastels
Re: 0.91" OLED doesn't show in I2C Scan, but green power LED comes on
Post by dastels »
It is showing up as I2C_Scan shows: the display is at 0x3C. It's on the STEMMA-QT I2C port, which is Wire1 not Wire. See https://learn.adafruit.com/adafruit-qt- ... or-3107922.
In the code you will need to pass a pointer to Wire1 to the Adafruit_SSD1306 constructor instead of a pointer to Wire.
ChrisElectron
dastels wrote: Sun Sep 25, 2022 10:11 pm It is showing up as I2C_Scan shows: the display is at 0x3C.
Lesson 1: I need to learn to read what the output actually means. I saw the 0x3C and thought that was the address of Wire1, not a device on Wire1.
dastels wrote: Sun Sep 25, 2022 10:11 pm In the code you will need to pass a pointer to Wire1 to the Adafruit_SSD1306 constructor instead of a pointer to Wire.
Lesson 2: Reading the docs doesn't just mean skimming and looking at the sample code.
I saw the I2C section and the idea that the STEMMA port would be on anything other than the first I2C bus never crossed by mind.
Thanks for the notes! The demo is running nicely. Now to see what I mess I can make of this! :)
dastels
Post by dastels »
Awesome! On some boards with a STEMMA-QT as well as 2C pins on the headers they're differend, but not all of them. It really does pay to read the guides associated with any new boards you get ;)
