Polyphonic FX Sound Board Recommendations
- onlinetracker
Hello all. I'm looking to make a fx sound board where I can press multiple buttons and play the sounds simultaneously for as long as the buttons are held down. Anyone have recommendations? Headphone/speaker output (either, both) are an option. I've been looking at the Adafruit METRO 328 with the Adafruit Music Maker and have it on order, but wouldn't mind a smaller footprint that allows me to use the Arduino IDE. Although I've seen matrix boards out there for the buttons, I'm looking for a 6x6 board and willing to custom make it to avoid the membrane options currently available. I'll be using switches for the sound board. There are a lot of options available and looking to find the best option for 3-5v mobile fx sound board. If you know of other threads, feel free to point me in that direction. I've read some, but time makes a different and I don't want to resurrect an old post unless the community doesn't mind questions in an old post. Thanks.
- mikeysklar
Re: Polyphonic FX Sound Board Recommendations
For smaller footprint and Arduino interfacing you should consider the Music Maker FeatherWing.
https://www.adafruit.com/product/3357
A FeatherWing M4 Express would be a good high performance controller board with plenty of memory.
https://www.adafruit.com/product/3857
The Trellis might be something to look into if you find the membrane suitable. The matrix options are 4x4, 8x8 and 4x8.
https://www.adafruit.com/?q=trellis&sort=BestMatch
- onlinetracker
Thanks for the lead. Much appreciated.mikeysklar wrote: ↑Sun Sep 25, 2022 5:47 pm For smaller footprint and Arduino interfacing you should consider the Music Maker FeatherWing.
Looks good, and available. I'll try a build with this in mind.mikeysklar wrote: ↑Sun Sep 25, 2022 5:47 pm A FeatherWing M4 Express would be a good high performance controller board with plenty of memory.
Because I have buttons already in play, membrane won't be suitable for the format of the FX sound board triggers and none of the matrix boards are in the shape I need. 6x6 and more compact. I'll end up making a custom PCB it seems.mikeysklar wrote: ↑Sun Sep 25, 2022 5:47 pm The Trellis might be something to look into if you find the membrane suitable. The matrix options are 4x4, 8x8 and 4x8.
Thanks again for the leads, I hope my BBCode isn't borked when this posts. I'm new to this forum. You, however, are awesome for providing an answer. Much appreciated.
- mikeysklar
Let us know how it goes with the MusicMaker. I figured the Trellis would not meet your needs, but thought it relevant to mention as it is so close in design specs.
