Neopixel chase with yellow to red gradient
rjenn2
Post by rjenn2 »
Using a neopixel ring, I am hoping to light each LED one by one, chasing around in a circular pattern and slowly fading from yellow to red. I have tried the below code, but it is only lighting up the first neopixel. I could use some advice on where I am going wrong. Thanks!
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, 2, NEO_GRB + NEO_KHZ800);
strip.begin();
strip.show();
  for (int x=0; x<=12; x++){
    for (int y=255; y>0; y--){
      uint32_t yellow = strip.Color(255, y, 0);
      strip.setPixelColor(x, yellow);
      strip.show();
mikeysklar
Re: Neopixel chase with yellow to red gradient
Post by mikeysklar »
What is the Adafruit product number of the NeoPixel ring? Sometimes when only one lights up it means you are initializing for the wrong type of NeoPixel device (eg. RGB, GRB vs RGBW).
Return to “Arduino”
