64x32 RGB LED Matrix - 4mm pitch
Product ID: 2278
I am reaching out with a question on the above product. Would you be able to give us more information on the interface needed for the display. I am currently working on my senior project in college and would like to purchase a microcontroller that can be used with the display. On the datasheet there was not much information on the interface, so if there is a more detailed
datasheet that would be helpful also ! I attached the datasheet given below.
More Info On LED Display Interface
- jiannanie
- Attachments
- DisplayDatasheet.pdf
- (248.8 KiB) Downloaded 2 times
- dastels
Re: More Info On LED Display Interface
Have you looked at the tutorial guide? https://learn.adafruit.com/32x16-32x32-rgb-led-matrix.
You can wire the matrix directly to an MCU board or use a shield https://www.adafruit.com/product/2601, Featherwing https://www.adafruit.com/product/3036, or matrix portal (MCU, wifi, and adapter all in one) https://www.adafruit.com/product/4745.
You don't say what your project is, but Adafruit has libraries for controlling these matrices.
