Python Programming Language Syntax & Commands
- RickyRivits
Looking for a Programming manual that helps me understand how to Code Stepper Motor applications inside Circuit Python. Found pre-programmed examples but at this point I need to understand the syntax & commands. Is there a manual I can read? Thanks for your time.
- rooppoorali
Re: Python Programming Language Syntax & Commands
You can start from here: https://www.tutorialspoint.com/python/p ... syntax.htm
- Franklin97355
You could start with the tutorial and, if you get stuck, ask here with specifics.
- westfw
There are some very nice online Python classes. While they're for Python (the general Language) rather than circuitPython (a subset/modified version of Python for manipulating hardware), they're probably a good starting place if you're interested in the general "Syntax and Commands."
I've like the Charles Severance "Python for Everyone" Series from U Michigan. "Dr Chuck" has an evangelical enthusiasm (not unlike Lady Ada!), and the course is available in several forms ( https://www.py4e.com/ ) (also, it's specifically aimed at people who are NOT CS majors.)
(Unfortunately, Coursera and EdX seem to have started charging for classes if you want to have the homeworks (auto-)graded, but you can still watch the videos and get the class materials for free.)
MIT has a more rigorous "CS101 using Python" class (for CS majors!) online as well. https://ocw.mit.edu/courses/6-0001-intr ... fall-2016/
- RickyRivits
To: Everyone. Thanks for the support. This is my problem with Python.
I had good results with python examples like simple blinks so I have the boot process down and I can load a program that runs... but with Stepper Motor files I am not getting anywhere with python. Although I have had great results with IDE programming. IDE proves my hardware is working and setup correctly but the Python software is just killing me. In my life I coded in Basic, C, and C++ and have extensive experiences with PLC's, Motor drives and many other products but this Python code is just killing me. I feel like I am just hacking and I hate that.
With IDE all the motor examples work like clockwork.
With Python...all examples for Stepper motors fail, know its a library problem.
I am working inside Python programming DC Motor + Stepper with both FeatherWing and Metro hardware both work fine when I use IDE.
So when I choose links found in the documents, I can manually download and then install libraries.
These are the ones I need.
adafruit_pca9685 ( But I Can't find this one in the download )
adafruit_bus_device ( Bingo...found this one aok )
adafruit_register ( bingo again Found this one too )
adafruit_motor ( Holy Moly Bingo found this one )
adafruit_motorkit ( Ahh...Can't find this one too ) and without it example code can't run. I see errors pointing to this.
I read all the guides over and over again and again but I really think the downloads are just not complete as two are just not there.
I know how to down load bundles and add a library. These two are just missing. I have asked other and they just point me to the same downloads...and guess what those files are still missing.
- Franklin97355
