Hi, I bought two 5V active buzzers and they don't wail. I noticed the problem when I soldered one onto my board and supply it with value(1) or 3.3V, and it struggles. I tried my second buzzer on a breadboard at 5V, and it struggles, too. Finally, I looked all over and found an identical buzzer I bought months prior, and it works.
Order 2917742-4674705103
https://www.adafruit.com/product/1536
Video recordings of problem:
https://youtu.be/vY-oAbyVXi0
https://youtu.be/Y9UZnhcNETA
5V Active Buzzers not working properly
- adafruit_support_carter
Re: 5V Active Buzzers not working properly
Just to see if it matters - what happens if you remove the current limiting resistor? Just apply 3V or 5V directly to the buzzers.
- jps2000
Polarity also matters
- dtran2
I now checked without the resistor and the problem is unchanged. I used just a 100 ohm resister. The + goes is on the 5V positive.
- adafruit2
thats odd it should be annoyingly beepy without issue. email support@adafruit for two more buzzers as replacement and we'll also check the stock
