Sending Data with HC-05 and Trinket M0
simonsterbb
Post by simonsterbb »
I am trying to use the Trinket M0 and the HC-05 to communicate with another Trinket/HC-05. Before getting them to communicate with each other, I am trying to separately send and receive data from my phone to the microcontroller.
I have succeeded in sending a signal from my phone to the Trinket over Bluetooth, but I have not been able to send a signal from the Trinket to my phone. When I try to Serial.write(), the signal is successfully transmitted to the serial monitor, but is not transmitted via the HC-05. The apps I have tried for receiving the signal are "Bluetooth Terminal" and "ArduTooth", which worked for sending the signal. Is there another library I should use? Below is a simplified version of my code.
#define SWITCH_PIN 2
int pin_value = LOW;
int old_pin_value = LOW;
  pinMode(SWITCH_PIN, INPUT);
  Serial.begin(9600);
      pin_value = digitalRead(SWITCH_PIN);
      delay(100);
    // If switch flips on, write "a"
    if (pin_value == HIGH && old_pin_value == LOW){
        Serial.write("a");
    // If switch flips off, write "b"
    else if (pin_value == LOW && old_pin_value == HIGH){
        Serial.write("b");
    old_pin_value = pin_value;
adafruit_support_mike
Re: Sending Data with HC-05 and Trinket M0
You're probably getting caught by buffering: every transmission protocol wraps the data you want to send (aka: 'in-band data' or IBD) in an 'envelope' of protocol data (aka: 'out-of-band data' or OOBD).
Adding a whole envelope's worth of OOBD to every byte of IBD is as inefficient as it's possible to be, so protocols try to be efficient by collecting fixed-size blocks of IBD in a buffer and sending a full buffer per transmission.
The .write() method puts data into the buffer, and the underlying code transmits the buffer when it's full. That means .write()s don't guarantee immediate transmission.
If you want to send less than a full buffer of data, use the .flush() method. That forces the underlying system to transmit and empty the buffer immediately.
