Raspberry Pi DC Motor Project Help
davidleejones
Post by davidleejones »
I am a beginner RaspberryPi user and have a simple project.
I have a DC motor that runs on 12 volts and draws 25 amps at stall.
I would like to use a raspberrypi to control the speed at which the dc motor rotates. The normal way would be with a manual dial of some sort, but I would like to be able to control remotely, either via bluetooth or RF remote, such as Keyfob 2-Button RF Remote Control - 315MHz.
What all would I need other than the raspberrypi to make this happen? I assume a key fob and receiver, but what would I use to control the voltage to the DC motor for a larger motor like this?
Any help is much appreciated.
Re: Raspberry Pi DC Motor Project Help
Do you need to control direction too, or just the speed?
davidleejones
Just speed. 1 direction is fine.
You could use a MOSFET like this one: https://www.adafruit.com/product/355
and control the motor speed via the MOSFET with a PWM signal from your Pi. You will need to add a heat-sink to the MOSFET if you will be driving the motor anywhere near its maximum rating.
To protect the MOSFET, you will also need a diode. It should be rated to handle at least the same current as the motor. You can see an example circuit in this tuorial: http://adam-meyer.com/arduino/N-Channel_MOSFET
If you would prefer an off-the-shelf motor-driver solution, I'd have a look at www.pololu.com.
