I've used the fontconvert tool to enable use of the "Barlow Bold" font on my display.
Centering this new font works as expected horizontally, but the font will not center vertically on the display.
I am able to output the width and height of the rendered string with the new font, so it is able to calculate the bounds.
If I change the font to one of the GNU FreeFonts, the same issue occurs.
Is what I am trying to do something that is not allowed with the custom fonts? How can I get these strings centered vertically on the screen?
Any help is appreciated!
The sketch code I am using is below:
// Include Libraries
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1327.h>
// Include Fonts
#include <Fonts/barlowblack8pt7b.h>
#include <Fonts/barlowblack24pt7b.h>
// Screen Dimensions in Pixels
#define screenWidth 128
#define screenHeight 128
// I2C Setup
Adafruit_SSD1327 display( screenWidth, screenHeight, &Wire, -1, 1000000 );
// Function to center text horizontally on the screen
void centerHorizontally( const String &textValue, int cursorXPos, int cursorYPos ) {
int16_t x1, y1;
uint16_t textWidth, textHeight;
display.getTextBounds( textValue, 0, 0, &x1, &y1, &textWidth, &textHeight );
display.setCursor( ( screenWidth - textWidth ) / 2, cursorYPos );
display.print( textValue );
// Function to center text horizontally & vertically on the screen
void centerPerfectly( const String &textValue, int cursorXPos, int cursorYPos ) {
int16_t x1, y1;
display.setCursor( ( screenWidth - textWidth ) / 2, ( screenHeight - textHeight ) / 2 );
#Initialization
Serial.begin( 9600 );
//while (! Serial) delay(100);
if (!display.begin( 0x3D )) {
Serial.println( "Unable to initialize OLED" );
while ( 1 ) yield();
display.clearDisplay();
display.display();
display.setTextWrap(false);
display.setTextColor( 0xFFFF );
#Gauge-Label-Text-Rendering
display.setFont( &Barlow_Black8pt7b );
centerHorizontally( "AFR", 0, 16 );
display.setFont();
#Gauge-Value-Text-Rendering
display.setFont( &Barlow_Black24pt7b );
centerPerfectly( "14.6", 0, 0 );
display.setFont();
display.display();
