I bought a 64x32 RGB LED Matrix - 4mm pitch PID: 2278 in order number #2895583-9334366871 on August 2nd.
I had it fully up and running with the mlb-scoreboard-led project as I was hoping to give it as a gift for christmas, and I just turned it on for the first time in a month to update it to the lastest version to test before the mlb season is over and it appears the screen is now faulty. Top left quadrant is a different color than it should be with two lines on top and bottom. I tested with rotating colors and the mlb project and it happens on both.
Thanks for any help.
Bad LED 32x62 Matrix?
- mikeysklar
Re: Bad LED 32x62 Matrix?
Thank you for the photos.
Did you end up doing any software or firmware updates since this was last running?
What is the power supply you are using?
Were you powering the Pi from a separate supply?
https://learn.adafruit.com/adafruit-rgb ... aq-3055727
- ZachPL
I did update the mlb-led-scoreboard project, but I ran these tests with the rgb matrix project and it happens with everything I run.mikeysklar wrote: ↑Sat Oct 01, 2022 3:37 pm Thank you for the photos.
I'm using the recommended switching power supply, I wasn't powering the pi from a seperate supply but I just tried that and it is still doing the same thing
- mikeysklar
Your power supply looks good. I see you are using a 5v/4A.
Did your ribbon cable ends get swapped between the matrix and the hat? I ask because the examples in the guide show the ribbon going the other direction (same orientation as you have for pin1).
Can you post a close up of the soldering on the HAT you have done. It looks reasonable from afar, but I'd like verify the flow is good up close.
What happens when you run the hzeller rgbmatrix demo code?
sudo ./demo -D0 --led-rows=32 --led-cols=64
- ZachPL
Hard to get my camera to focus, but I think this shows it pretty goodmikeysklar wrote: ↑Sun Oct 02, 2022 4:26 pm Your power supply looks good. I see you are using a 5v/4A.
I switched the cable around just to see and the same thing was happening.
I tried the demo code it was changing so fast it was hard to get a good picture but the top left quadrant and then those 2 lines were still messed up.
- mikeysklar
The soldering is not bad, but some of the joins might need a tiny bit more flow. Can you remove the HAT and go over the joints one more time?
- ZachPL
Sure I will soon and report back. Thanks.
- ZachPL
Just reflowed and added some solder to every pin and same issue unfortunately.mikeysklar wrote: ↑Sun Oct 02, 2022 7:03 pm The soldering is not bad, but some of the joins might need a tiny bit more flow. Can you remove the HAT and go over the joints one more time?
- mikeysklar
Thank you for going over the soldering.
Which model of Pi are you using? Pi 3 or Pi 4?
If it is a Pi 4 you might need add the slowdown.
sudo ./demo -D0 --led-rows=32 --led-cols=64 --led-slowdown-gpio=4
- ZachPL
It's a 3b+ I was already running the slowdown gpio with the mlb project as well (to cut down on flickering) and it doesnt make a differencemikeysklar wrote: ↑Mon Oct 03, 2022 5:15 pm Thank you for going over the soldering.
- mikeysklar
I see thank you for the clarification.
Here are the issues.
You are a month passed the 30-day warranty when opening this issue.
We don't know if the issue with the HAT, RGB Matrix, power supply or a software change.
This is a bad place to be. Do you have any thoughts on how to narrow things down? That you had a working configuration is reassuring.
- ZachPL
I'm willing to purchase another, as I was thinking about making one of these for myself as well. If I buy one and this one works are we able to process an exchange still if it turns out this one is broken?
- mikeysklar
I think that could be a workable solution. Were you planning on getting another matrix hat + 32x64 display and 4A power supply?
- ZachPL
Yes I would need to purchase those aswell.mikeysklar wrote: ↑Tue Oct 04, 2022 3:21 pm I think that could be a workable solution. Were you planning on getting another matrix hat + 32x64 display and 4A power supply?
- mikeysklar
Cool. Well lets move forward with this plan. I'll help you with any issues and the return process if something is faulty.
