Dear all,
I am seeking advice for the following:
I have set up my Raspberry Pi 4 with the yellow 7 segment display 1.2 inch and the backpack.
For some reason only the dots want to turn on and of with "display.fill(1)"
The digits do not want to respond to my code.
There must be something critical I do wrong - but I am not sure what it is.
Does anyone have an advice for me?
BigSeg7x4 only dots turn on and off
- Franklin97355
Re: BigSeg7x4 only dots turn on and off
How are you connecting it and what program are you using? Can you post a picture of the setup?
- eaderigt
Hi Franklyn,
Thank you.
I am using python and have gone through the tutorial here:
https://learn.adafruit.com/adafruit-led ... t-backpack
Thank you.
- Attachments
- IMG_4701.jpg (189.46 KiB) Viewed 131 times
- IMG_4702.jpg (122.45 KiB) Viewed 131 times
- IMG_4703.jpg (212.62 KiB) Viewed 131 times
- eaderigt
two more photos
- Attachments
- IMG_4700.jpg (146.4 KiB) Viewed 128 times
- IMG_4699.jpg (156.29 KiB) Viewed 128 times
- eaderigt
The strange thing I am facing is:
The display does show the colon -> display.print(':')
And it lites all dots -> display.fill(1)
With the code below:
# SPDX-FileCopyrightText: 2019 Mikey Sklar for Adafruit Industries
import time
import board
from adafruit_ht16k33.segments import BigSeg7x4
#from adafruit_ht16k33.segments import Seg7x4
i2c = board.I2C()
display = Seg7x4(i2c)
# Clear the display.
display.fill(0)
display.brightness = 0.9
display.print(':')
time.sleep(1)
display.print("1234")
display.show()
time.sleep(1)
display.fill(0)
time.sleep(1)
display.fill(1)
time.sleep(1)
display.fill(0)
print("ready")
- eaderigt
hi Franklin, can you think if anything I did wrong?
- adafruit_support_carter
Did you try?
It's not clear from your code. It's being imported, but not used.
display = BigSeg7x4(i2c)
- eaderigt
hi, thank you.
yes - I corrected that. It was the error in the code I posted here after doing trial and error.
- eaderigt
posting one mor pic to show what display.fill(1) is doing
- Attachments
- IMG_4706.jpg (155.57 KiB) Viewed 103 times
OK, let's check other connections. Can you post a photo of the backside of the backpack so we can check the soldering on the LED module pins.
- eaderigt
this is the backside with the pins
- Attachments
- IMG_4709.jpg (123.5 KiB) Viewed 95 times
- IMG_4710.jpg (116.86 KiB) Viewed 95 times
- IMG_4711.jpg (69.72 KiB) Viewed 95 times
- eaderigt
and the full view
- Attachments
- IMG_4708.jpg (178.32 KiB) Viewed 95 times
- dastels
I'd redo the soldering of the display to the board. It doesn't look bad, but the LEDs that light up are all on one column of the controller. The LEDs that aren't lighting up are on other columns.
- eaderigt
ok. I think I am going to try that. Can you maybe help me and tell me which columns is the one that you think that might have a soldering problem?
- dastels
The ones for the 4 digits. There aren't many connections, just reflow all of them. The solder should flow into the hole around the pin and result is a tent-like shape. As I said, they don't look particularly bad, but it's pretty much always the first thing to try.
Specifically the digits are on pins 2-5 of the display. See page 3 of the datasheet to identify pin 1.
