macropad rp2040 can't find I2c adress of a neokey 1x4
- vuduc09
I buy 2 of them and plan to asem them. I am noob and i use a sample code of macrodpad rp2040. when I connect, macropad can't find I2c address of neokey 1x4 and neokey is inactive. What should I do now?
- mikeysklar
Re: macropad rp2040 can't find I2c adress of a neokey 1x4
Can you post a photo of how you have connected the MacroPad to the NeoKey? I want to confirm the stemma cable color orientation.
What code did you run to scan for the i2c address of the NeoKey on the MacroPad?
- vuduc09
mikeysklar wrote: ↑Sun Oct 02, 2022 5:47 pm Can you post a photo of how you have connected the MacroPad to the NeoKey? I want to confirm the stemma cable color orientation.
https://drive.google.com/file/d/1yxOlJo ... sp=sharing
// Scanning takes a while so we don't do it all the time
if ((j & 0x3F) == 0) {
Serial.println("Scanning I2C: ");
Serial.print("Found I2C address 0x");
for (uint8_t address = 0; address <= 0x7F; address++) {
Wire.beginTransmission(address);
i2c_found[address] = (Wire.endTransmission () == 0);
if (i2c_found[address]) {
Serial.print("0x");
Serial.print(address, HEX);
Serial.print(", ");
Serial.println();
- vuduc09
I found that my stemma qt in my neokey is not working. When i change to use header pin it's work.
it's annoying
it's annoying
- mikeysklar
Good to know the breakout pin header works.
That means the issue is likely one of the following:
1) The Stemma QT cable is reversed
2) The Stemma QT cable is not working
3) The Stemma QT connector (on either side) is damaged.
Can you use a multimeter to help narrow down which scenario is happening.
Was the Stemma cable purchased from Adafruit?
