Mike,
I ran the code with only one line un-commented line at a time. So the seconds numbers are correct.
I was in a hurry when I sent it. I had just been called for dinner and my wife had made chili from scratch with cornbread. So I had not proofread it before send.
Bruce
Run code.py from SD card
- mikeysklar
Re: Run code.py from SD card
Bruce,
I understand, chili first.
We should focus on what needs to go into a CircuitPython issue. I'd like you to open if you do not mind. Maybe the minimal code.py with the /sd/lib path appendage and a /sd/lib that contains the current bundle. That should be enough to see the initial lag, correct?
- blakebr
Mike,
Chili first, CP second.
Let me figure out just how I want to approach this...
Bruce
Bruce
