Dear Adafruit Team,
We have plan to purchase serial to USB converter boards for medical device. In the medical field, we have an obligation to be complient to the UL94 V-2 standard or better.
We have found 2 references in your catalog by seeing the inscription on the PCB (on the picture), these are the product ID : 284 and 2264.
The question is : where can we found the UL94 V-0 certificates for those products?
Thanks in advance,
Malik
- mikeysklar
Re: UL94 V-0 certificates
The UL94 is specific to the PCB not the assembled products.
- Malik34
Thank you mikeysklar for your answer, of course the UL94 is specific to the PCB, so is it any way to get it in numeric version for the technical file?
- mikeysklar
The answer is probably no. We do not have a digital certificate for the UL94 fire rating on Adafruit PCBs with the marking. However, you might want to check-in with [email protected] as they usual provide the RoHS certificates when requested. There could be some sort of UL fire rating document that I've not seen before.
- Malik34
Ok mikeysklar, thank you, I will try to go this way..
