Bi-Color 24 Bargraph multiple led's
- SrGadget
Question: I recently purchased a Bi-Color 24 Bargraph from you and using it just fine with Arduino nano board. the question I have in the code " bar.setBar(12, LED_GREEN);" if I want easily set say led 0 through and including 11 what would the syntax be ? I have look in your doc's and the forum to no avail I have tried a few thing also with no luck. Any thoughts ideas or guidance would be greatly appreciated....
- dastels
Re: Bi-Color 24 Bargraph multiple led's
Maybe:
Then call it:
void draw_bar(uint8_t first, uint8_t last, uint8_t color) {
for (int led_number = first; led_number <= last; led_number++) {
bar.setBar(led_number, color);
draw_bar(0, 11, LED_GREEN);
- SrGadget
Many thanks Dave I need to read up on using "uint8_t" your a gentleman and a scholar .... Have a good weekend.
- dastels
uint8_t is just a standard type alias for unsigned 8 bit integers. I.e. a byte.
