Assembled minty boost not working, chip overheating
Ideas and questions about MintyBoost kits
00luyan
Post by 00luyan »
I ordered 5 minty boost kits, and upon build completion, one does not work properly.
The chip gets extremely hot when the batteries are connected and does not charge properly. I looked over the solder joints and everything looks fine. I then took one of the other 1302 chips from a good build and swapped it and everything worked fine.
So it seems I have a bad chip, is there any way I can get a replacement?
mikeysklar
Re: Assembled minty boost not working, chip overheating
Post by mikeysklar »
When did you order the kits and were the from Adafruit or a 3rd party?
Can you post a photo of the board that is not working (top and bottom).
Return to “MintyBoost”
