Itsy Bitsy M4 and inverted UART
Mandel
Post by Mandel »
I have a small project where I need an inverted UART signal and I wanted to solve it with my new Itsy Bitsy M4. I read that it should be possible to invert both RX and TX. I have found that this requires setting bit 10 (RXINV) of the CTRLA register to 1 and bit 9 (TXINV) of the CTRLA register to 1 as well.
Sounds easy, but I have no idea how to do it. I have never dealt with registers. After googling for a while I'm a bit desperate.
Does anyone have any experience with inverted UART on a SAMD51 or know how to change the CTRLA register?
Thanks a lot!
blnkjns
Re: Itsy Bitsy M4 and inverted UART
Post by blnkjns »
Not totally sure, but I believe this happens if you enable the pull-up resistor.
What happens if you use
pinMode(0,INPUT_PULLUP);
pinMode(1,INPUT_PULLUP);
adafruit_support_mike
Mandel wrote: Wed Oct 26, 2022 10:28 am Does anyone have any experience with inverted UART on a SAMD51 or know how to change the CTRLA register?
Unfortunately, poking around in the SERCOM settings doesn't have an easy option. Too many things are interconnected, and rely on a large chunk of background information.
You can sidestep the problem in hardware by running the TX and RX signals through an inverter like the 74acht14:
https://www.adafruit.com/product/3877
Return to “Itsy Bitsy Boards”
