So I tried to install WipperSnapper on Adafruit QTPY ESP32-S2
Double-clicked Reset -> QTPYS2BOOT appears in Windows
Moved wippersnapper.qtpy_esp32s2.1.0.0-beta.53.uf2 onto the drive -> Drive reboots
Now the LED is solid yellow but I cant see the Wipper drive
What can I do?
Wipper Drive not showing on QTPY ESP32-S2
- mikeysklar
Re: Wipper Drive not showing on QTPY ESP32-S2
Have you hard reset the board (remove the USB power)?
Did you add the device to Adafruit IO?
- Lhurgoyf
I added the device from Adafruit IO (that's where I got the uf2 file from).
I reinserted the USB cable and nothing happened, still solid yellow. I plugged it into another USB Port, there I get a warning message "USB device not recognised". I get this in every port I tried except the one I started with, which happens to be a special bios flash port.
- Lhurgoyf
Tried it now on a different PC, and there it works.
- mikeysklar
Ah, thank you for sharing your solution. Was there a difference between the two PCs? Models or OS version that was relevant?
- Lhurgoyf
One was an AMD Ryzen 7 5800X Desktop PC with all ports USB 3.2, the other one was an Intel 8th gen laptop, with I think USB 3.0 ports, both Windows 10
- mikeysklar
Gotcha. Thank you for the followup. This is helpful.
