Hi there, I am following the "Neo Pixel Spats" tutorial for programming neopixles using a Gemmo M0 and MakeCode.
When I reset my Gemma M0 and it is plugged in to the macbook, I see it pop up with CircuitPython instead of GemmaM0 and when I drag my MakeCode file onto it I am informed that there is no space. Is this info outdated? Can I use this code?
Help using Gemme M0 W/ MakeCode
- blnkjns
Re: Help using Gemme M0 W/ MakeCode
The .hex file of makeCode can replace the CircuitPython runtime. Did you try uploading it after double-tap the reset button? Then you enter the bootloader, not the USB drive mode of CircuitPython.
