ADABOX020 - LED Glasses - ValueError: No I2C device at address: 0x30
Wearable electronics: boards, conductive materials, and projects from Adafruit!
ankurdarji
Post by ankurdarji »
I am having issues getting the LED glasses to work. I get the following error. Note that this is running the code from the is31fl3741_glassesrings.py example. I tried the projects from CircuitPython EyeLights Starter Projects and have the same issue so I started to try in individual examples to try debug.
code.py output:
  File "code.py", line 9, in <module>
  File "adafruit_is31fl3741/adafruit_ledglasses.py", line 256, in __init__
  File "adafruit_is31fl3741/__init__.py", line 280, in __init__
  File "adafruit_is31fl3741/__init__.py", line 105, in __init__
If I manually scan the I2C, I see 2 devices and 0x30 (DEC 48) is found:
>>> import board
>>> import adafruit_is31fl3741
>>> from adafruit_is31fl3741.adafruit_ledglasses import LED_Glasses
>>> i2c = board.I2C()
>>> i2c.try_lock()
True
>>> i2c.scan()
[24]
>>> i2c.scan()
[24, 48]
>>> i2c.scan()
[24, 48]
>>> i2c.unlock()
>>> glasses = LED_Glasses(board.I2C(), allocate=adafruit_is31fl3741.MUST_BUFFER)
  File "<stdin>", line 1, in <module>
Any suggestions? Could this be a bad LED Glasses board? I am able to access the lis3dh accelerometer and successfully run the code from the example lis3dh_simpletest.py
Thanks for the Support!
dastels
Re: ADABOX020 - LED Glasses - ValueError: No I2C device at address: 0x30
Post by dastels »
Are CircuitPython (7.3.3 from https://circuitpython.org/board/adafrui ... _nrf52840/) and matching libraries (7.x from https://circuitpython.org/libraries) up to date?
ankurdarji
Hi Dave,
Thanks for the quick response. To answer your question yes I had made sure I was using the latest CircuitPython and matching libs.
Actually, I found the issue... it was a bent pin the STEMMA QT connector. Not really sure how it got bent, but after carefully straightening the pin and reconnecting the cable, the LED Glasses came to life!
Thanks for the support!
Ankur
dastels
Post by dastels »
Awesome!
Return to “Wearables”
