Metro M4 Airlift Lite won't boot Arduino program
- bgoolsby
How can I make the Metro M4 boot into an Arduino program on power-up? I don't want to use CircuitPython. My programs work when I compile and download using the Arduino IDE, but when I simply plug in a 5V micro-USB power supply the program does not run.
- mikeysklar
Re: Metro M4 Airlift Lite won't boot Arduino program
Can you post a program you are running on the Arduino side? It might be waiting for a serial console. Several of the Adafruit examples use that.
- bgoolsby
Here is the code. It does wait for Serial to open - I will delete that part tonight and try it.
// 10/18/22 - Working. Adafruit IO feed is "analog" and dashboard is "Analog in".
// 10/28 - Added BME280 to send humidity. Using Adafruit library example bme280test.ino.
// 10/30 - Added separate temp and humidity feeds. This works and feeds to Dashboard
// Crawlspace. Works when compiled and downloaded from Arduino, but does not work
// when plugged into a 5V PS.
// Adafruit IO Analog In Example
// Tutorial Link: https://learn.adafruit.com/adafruit-io-basics-analog-input
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Todd Treece for Adafruit Industries
// Copyright (c) 2016 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/********************* Adafruit IO Configuration ****************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
Adafruit_BME280 bme; // I2C mode
// analog pin 0
#define PHOTOCELL_PIN A0
// feed states
float new_h = 0;
float last_h = -1;
float new_t = 0;
float last_t = -1;
// set up the feeds
AdafruitIO_Feed *feed_temp = io.feed("cs_temp");
AdafruitIO_Feed *feed_humid = io.feed("cs_humid");
pinMode(LED_BUILTIN, OUTPUT); //the LED marked "L"
// start the serial connection
Serial.begin(115200);
// wait for serial monitor to open
while(! Serial);
// connect to io.adafruit.com
Serial.print("Connecting to Adafruit IO");
io.connect();
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.println(io.statusText());
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(250); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
delay(250);
// we are connected
Serial.println();
// BME280 setup - default settings
unsigned status = bme.begin();
// You can also pass in a Wire library object like &Wire2
// status = bme.begin(0x76, &Wire2)
if (!status) {
Serial.println("Could not find a valid BME280 sensor, check wiring, address, sensor ID!");
Serial.print("SensorID was: 0x"); Serial.println(bme.sensorID(),16);
Serial.print(" ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
Serial.print(" ID of 0x56-0x58 represents a BMP 280,\n");
Serial.print(" ID of 0x60 represents a BME 280.\n");
Serial.print(" ID of 0x61 represents a BME 680.\n");
while (1) delay(1000);
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
float h = bme.readHumidity();
h = float(int(h*2.0-0.5)) / 2.0; //round to 1/2 percent
new_h = h;
float t = bme.readTemperature();
t = t*1.8 + 32; // to F
t = float(int(t*2.0-0.5)) / 2.0; //round to 1/2 degree
new_t = t;
if(new_h != last_h) {
// save the new_h state to the analog feed
Serial.print("Sending H -> ");
Serial.print(new_h);
Serial.println(" %");
feed_humid->save(new_h);
if(new_t != last_t) {
// save the new_t state to the analog feed
Serial.print("Sending T -> ");
Serial.print(new_t);
Serial.println(" deg");
feed_temp->save(new_t);
// save last state
last_h = new_h;
last_t = new_t;
// wait - free IO account limits updates to 30/minute
// 2 feeds count as 2 separate updates
delay(4000);
- mikeysklar
while(! Serial);
