Not sure if this is the right place to ask for suggestions, so if not, please let me know the appropriate forum.
I just purchased several 6 inch 10-pin (2 rows of 5) header sockets, product ID 370. I think this will connect to the SMARC iMX8 carrier board I am working on. But I don't know how to use/connect to the other end. These 10-pin headers are the input/output for headsets on the board and I need to connect some military style headsets to these boards. The headsets I have use heavy duty connectors on the cord and I need to cut off the connectors, strip the wires and connect these wires to the 10-pin headers on the carrier board.
I just ordered the 6 inch flat cables, one end connects to the carrier board and I need something to connect to the other end that I can use to connect the bare wires from the headsets.
Does Adafruit make a small circuit board that has the mating 10-pin header on it and some solder pads that I can use to solder the headset wires to? Any suggestions on what is the best way to connect bare wires to the 10-pin headers on this carrier board?
Thanks,
-Andres
how best to hook up to circuit board
- adafruit_support_carter
Re: how best to hook up to circuit board
How about this option?
https://www.adafruit.com/product/2102
It's shown attached to a Perma-Proto, which you could use as general purpose breakout and solder the other wires to. It's available in a 1/4 size:
https://www.adafruit.com/product/1608
- gonzo48
Thanks for your reply and suggestions. I just order several items.
-Andres
-Andres
