having problems with MCP23017
jato1981
Post by jato1981 »
I'm trying to connect a MCP23017 to my Arduino board without any luck. I did this in the past many times but now it seems like something is going wrong.
I already tried to connect multiple MCP23017 chips but they all have the same issue.
I've tried connecting it to a Wemos D1 mini and a regular Arduino Uno board.
All have the same problems. Sometimes it works once and than it stops working and nothing seems to help.
I now connected the board to an Arduino Uno:
Arduino --> MCP
+5V --> Vdd
GND --> Vss
SDA --> SDA
SCL --> SCL
MCP:
RESET --> 10k resistor --> +5V
A0 --> GND
A1 --> GND
A2 --> GND
When I run the scanner sketch I get this result
I2C Scanner
Scanning...
I2C device found at address 0x27 !
done
Scanning...
done
Scanning...
I2C device found at address 0x20 !
done
Scanning...
done
Scanning...
done
Scanning...
done
Scanning...
done
Scanning...
done
Scanning...
done
and so on...
The address of the device changes and sometimes it even finds 2 devices at the same time.
What's going on here? I'm getting crazy trying to solve this.
Any suggestions?
bidrohini
Re: having problems with MCP23017
Post by bidrohini »
I2C devices often need 4.7K ohm pull up resistors. https://tronixstuff.com/2011/08/26/ardu ... -tutorial/
Does your MCP23017 module already have these resistors on board?
adafruit_support_mike
Post a photo showing your hardware and connections and we'll take a look. 800x600 images usually work best.
Return to “Arduino”
