Tico servo library on Arduino Nano Every?
redhuck
Post by redhuck »
I tried TicoServo library on Arduino Nano Every, but it gives me a long error messge and won't run. It says it can't run because Nano Every has megaavr architecture. Is there a way to fix this?
westfw
Re: Tico servo library on Arduino Nano Every?
Post by westfw »
The TiCoServo library uses one of the AVR timers to generate the Servo pulse directly, instead of using a partially-interrupt based scheme that neopixels interfere with.
The chip on the Every (a megaAVR atmega4809) has entirely different timers, so essentially it needs a completely different library :-( (although, the principles should stay the same.)
