Motor Shield V2 - GND Question
guibot
Post by guibot »
I have a Motor Shield v2 connected to an ESP32.
I was having shutdown issues from the Motor Shield.
My power source is 5V - 4 Amp, so I beleive is good enough to drive four little motors.
I noticed that the GND on the Power Terminal Block is not connected to the rest of the Motor Shield circuit. I connected both GND's and the shutdowns stopped.
I wonder if this is a good practice? Should I be aware of anything else?
Franklin97355
Re: Motor Shield V2 - GND Question
Post by Franklin97355 »
I don't have a motor shield to check but in most cases tying the ground is the common practice since it is a path for the signal return.
guibot
Post by guibot »
Exactly, I always connect GND's.
My question is, why isn't the GND of the motor drivers, connected to the Logic Circuit on the Shield?
I beleive there must be a reason.
All the grounds are connected on the board. Please refer to the schematic: https://learn.adafruit.com/assets/9536
guibot
Post by guibot »
It might be true in the schematic, but If I perform a test continuity with the multimeter it doesn't show any connection between logic and motor driver GND.
please post some clear photos of the front and back of the board.
guibot
Post by guibot »
sorry, my mistake
tested again and GND's are connected
