This is the 2.8" TFT Touch Shield for Arduino with Resistive Touch Screen I have: https://www.adafruit.com/product/1651
Are there any noob-friendly guides, as I'm a bit of a dumb potato?
This is the code in question:
#include "TimerOne.h"
#include <Encoder.h>
#include <stdint.h>
#define DEBUG
#include <TouchScreen.h>
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <Fonts/FreeSans9pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans12pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans18pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold24pt7b.h> // Hardware-specific library
// These are the pins for the shield!
#define YP A2 // must be an analog pin, use "An" notation!
#define XM A3 // must be an analog pin, use "An" notation!
#define YM 8 // can be a digital pin
#define XP 9 // can be a digital pin
//IM - Touch Screen presure
#define MINPRESSURE 10
#define MAXPRESSURE 10000
//IM - Define the limits of the touch screen
#define TS_MINX 204
#define TS_MINY 195
#define TS_MAXX 948
#define TS_MAXY 910
//IM - TRINAMIC 2130 STEPPER DRIVER
#include <SPI.h> // SPI FOR SPI COMMS to the 2130 driver
#include <TMC2130Stepper.h>
#include <TMC2130Stepper_REGDEFS.h>
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
#define LCD_CS A3 // Chip Select goes to Analog 3
#define LCD_CD A2 // Command/Data goes to Analog 2
#define LCD_WR A1 // LCD Write goes to Analog 1
#define LCD_RD A0 // LCD Read goes to Analog 0
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// Assign human-readable names to some common 16-bit color values
// Modify these to match the colorspace of your LCD
#define WHITE 0x0000 //
#define YELLOW 0x001F //
#define CYAN 0xF800 //
#define PURPLE 0x07E0 //
#define RED 0x07FF //
#define GREEN 0xF81F //
#define BLUE 0xFFE0 //
#define BLACK 0xFFFF //
#define PIN_BATTVOLT 15
#define STEPSMM 160
//IM - Pins for the Encoder with button. If the encoders running backwards swap enc0 and enc1 pins
#define PIN_BUTTON 19
#define PIN_ENC0 21 //encoder pin 1
#define PIN_ENC1 20 //encoder pin 2
//IM - Stepper Driver Enable Pin
#define PIN_ENABLE 40
#define PIN_DIR 42
#define PIN_STEP 41
#define PIN_CS 53
#define MOSI_PIN 51
#define MISO_PIN 50
#define SCK_PIN 52
//IM - Step and direction pin settings for the Stepper driver
#define MAX_SPEED 40 // In timer value
#define MIN_SPEED 1000
#define STALL_VALUE 5 // [-64..63]
#define DEBOUNCE 300
#define MINRUNTIME 10000
//number of battery voltage points
#define LOOKUP 20
Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
long day = 86400000; // 86400000 milliseconds in a day
long hour = 3600000; // 3600000 milliseconds in an hour
long minute = 60000; // 60000 milliseconds in a minute
long second = 1000; // 1000 milliseconds in a second
//IM - Instansiate the encoder (on the rotary button) and tell it what pins we have used
Encoder myEnc(PIN_ENC1, PIN_ENC0);
//Config for the Trinamic 2130 set the pins pins
TMC2130Stepper driver = TMC2130Stepper(PIN_ENABLE, PIN_DIR, PIN_STEP, PIN_CS);
long oldPosition = 0;
//long MaxSlide = 73235; //IM - Test value for max slide (aprox 1mtr)
long MaxSlide = 0; //IM - holds the maximum number of steps for the length of the slide rail. Its set during initialisation proccess.
long calSteps = 0; //IM - holds the value of steps whilst performing the calibration.
long RailLength = 0; //IM - holds the value for the lenght of the rail;
float StepsPerMM = 80.3; //IM - the number of steps on my stepper motor that cover 1mm of rail travel.
volatile long numruns = 0;
volatile long period = 10000;
volatile long carragePos = 0; //the absolute carrage position on the slider.
volatile long lastTriggered = 0;
long nextBattMillis = 0;
long runtime = 0;
long offset = 0;
long sspeed = 0;
long decimals = 0;
//IM - Defines the mid point of the touch screen, this will determin the direction of movment, buy pressing either side of this line.
int ts_MID = 195;
byte oldDays = 0;
byte oldHours = 0;
byte oldMinutes = 0;
byte oldSeconds = 0;
boolean buttonPressed = false; //Holds the value seeing if the button has been pressed by the user
boolean srunning = false;
boolean sdir = 0; //Bit Direction of travel of the motor
boolean oldsdir = !sdir; //Bit holding the last known Direction of travel of the motor
boolean needsInit = false;
boolean drawnStatusBlank = 1;
boolean drawnStatus = srunning;
boolean driverEnabled = false; //set the default to the stepper driver disabled.
boolean calibratedSlider = false; //sets true if the slider rail has been calibrated to the length.
boolean stall = false; //set the motor stall value to false.
boolean TMC2130enabled = false;
boolean carrageHomed = false; //has the carraged reached its home position (during calibration)
boolean lcdFlipped = false; //has the LCD been installed physically upsidedown?
boolean haltCarrage = false;
boolean countCarrage = true;
boolean carrageHalted = false;
boolean stallSleep = false; //some times we dont want to detect a motor stall, like right after it just happend.
int stallSleepDuration = 1000;
int calibrationStep = 0; //IM - stores the value of the calibrations step 1 - 3. 3 is fully calibrated and homed.
float rawVolt;
float volt;
int checkInerval = 50; //use as a delay to count down too.
void catchButton() {
if (lastTriggered + DEBOUNCE < millis()) {
buttonPressed = true;
lastTriggered = millis();
Serial.print("catchButton: Button Pressed");
//enable the stepper driver
void enableTMC2130(){
Serial.println("enableTMC2130: stepper ENABLED");
digitalWrite(PIN_ENABLE, LOW);
TMC2130enabled = true;
//dissables the stepper driver
void disableTMC2130(){
Serial.println("disableTMC2130: stepper dissabled");
digitalWrite(PIN_ENABLE, HIGH);
//IM - VSense for Trinamic 2130
bool vsense;
//IM - RMS current for Trinamic 2130
uint16_t rms_current(uint8_t CS, float Rsense = 0.11) {
return (float)(CS+1)/32.0 * (vsense?0.180:0.325)/(Rsense+0.02) / 1.41421 * 1000;
//IM - Sets up the screen based on its physical mounted positon. Some screens may be mounted upsidedown for physical reasons
//this flips the image if required so the screen contents appear the right way up for the user. Other thigs get messed up when
//the screen is flipped round so we must account for that tool, setting the LCDFlipped bool helps track.
void SetScreenOrientation(bool flip){
if(flip){
tft.setRotation(3);
lcdFlipped = true;
else{
tft.setRotation(1);
lcdFlipped = false;
//##################################### SETUP #####################################
#ifdef DEBUG
Serial.begin(250000);
Serial.println(F("TFT LCD test"));
Serial.print("TFT size is ");
Serial.print(tft.width());
Serial.print("x");
Serial.println(tft.height());
#endif // DEBUG
Serial.println("Setup Started");
Serial.println("Instansiate TMC2130");
//set TMC2130 config
driver.begin();
driver.rms_current(600); // mA
driver.microsteps(16);
driver.diag1_stall(1);
driver.diag1_active_high(1);
driver.coolstep_min_speed(0xFFFFF); // 20bit max
driver.THIGH(0);
driver.semin(5);
driver.semax(2);
driver.sedn(0b01);
driver.sg_stall_value(STALL_VALUE);
driver.stealthChop(1);
Serial.println("Set stepper interrupt");
// Set stepper interrupt
cli();//stop interrupts
TCCR1A = 0;// set entire TCCR1A register to 0
TCCR1B = 0;// same for TCCR1B
TCNT1 = 0;//initialize counter value to 0
OCR1A = 256;// = (16*10^6) / (1*1024) - 1 (must be <65536)
//turn on CTC mode
TCCR1B |= (1 << WGM12);
// Set CS11 bits for 8 prescaler
TCCR1B |= (1 << CS11);// | (1 << CS10);
// enable timer compare interrupt
TIMSK1 |= (1 << OCIE1A);
//sei();//allow interrupts
//TMC2130 outputs on (LOW active)
disableTMC2130();
vsense = driver.vsense();
//IM - SET THE STATE OF ALL THE PINS WE WILL BE USING
//IM - Set the pins for the stepper driver
//pinMode(PIN_STEP, OUTPUT); //step pin
//pinMode(PIN_DIR, OUTPUT); //direction pin
//pinMode(PIN_ENABLE, OUTPUT); //enable pin
//IM - Set the initial pin states
digitalWrite(PIN_BUTTON, HIGH); //IM - set the initial state of the button pin to high
digitalWrite(PIN_ENABLE, LOW); //IM - set the initial state enable pin for the stepper driver
tft.reset();
uint16_t identifier = tft.readID();
if (identifier == 0x9325) {
#ifdef DEBUG
Serial.println(F("Found ILI9325 LCD driver"));
} else if (identifier == 0x9328) {
Serial.println(F("Found ILI9328 LCD driver"));
} else if (identifier == 0x7575) {
Serial.println(F("Found HX8347G LCD driver"));
} else if (identifier == 0x9341) {
Serial.println(F("Found ILI9341 LCD driver"));
} else if (identifier == 0x8357) {
Serial.println(F("Found HX8357D LCD driver"));
#endif // DEBUG
} else {
#ifdef DEBUG
/*Serial.print(F("Unknown LCD driver chip: "));
Serial.println(identifier, HEX);
Serial.print(F("I try use ILI9341 LCD driver "));
Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
Serial.println(F(" #define USE_ADAFRUIT_SHIELD_PINOUT"));
Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
Serial.println(F("If using the breakout board, it should NOT be #defined!"));
Serial.println(F("Also if using the breakout, double-check that all wiring"));
Serial.println(F("matches the tutorial."));*/
#endif // DEBUG
identifier = 0x9341;
tft.begin(identifier);
//main timer for the slider application
Timer1.initialize(period); // initialize timer1, and set a 1/2 second period
// Timer1.pwm(9, 512); // setup pwm on pin 9, 50% duty cycle
Timer1.attachInterrupt(callback); // attaches callback() as a timer overflow interrupt
Timer1.stop();
// IM - This is the interupt that will fire when the button is pressed
attachInterrupt(digitalPinToInterrupt(PIN_BUTTON), catchButton, FALLING);
//##################################### LCD ORIENTATION #####################################
//IM - Set the screen orientation. True is normal, False upsideown.
SetScreenOrientation(true);
tft.fillScreen(BLACK);
updateLCDTime(true);
updateLCDStatus();
rawVolt = ((float) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT)) / 5;
volt = toVolt(rawVolt);
//enable the stepper motor.
enableTMC2130();
//IM - Run the stepper motor.
//IM - this runs every half step
void callback()
//IM - If the device has been calibrated we can check we dont hit the end of the rail
if(calibratedSlider){
//Run the position as a half time
if(countCarrage){
//if the direction is false then we are moving away from the home position towards MaxSlide
if(sdir == true){
if(carragePos != MaxSlide){
//if it does then stop
carragePos++;
else{
haltCarrage = true;
//otherwise were heading for home watch out for 0
}else{
if(carragePos != 0){
carragePos--;
}else{
haltCarrage = true;
countCarrage = false;
}else{
//IM - Unless halt carrage is true run the slider
if(!haltCarrage){
numruns++;
digitalWrite(PIN_STEP, digitalRead(PIN_STEP) ^ 1);
}else{
if(!carrageHalted){
Serial.println("############ Carratge halted! ############");
//stopSlider();
catchButton(); //IM - emulate the button being pressed.
carrageHalted = true;
}else //if its not calibrated we'll just hit the buffers.
numruns++;
void stopSlider(){
Serial.println("############ stopSlider! ############");
srunning = 0;
//disableTMC2130();
Timer1.stop();
updateLCDStatus();
//cDir is ture for left false for right. Unless the screen has been flipped
void carrageDirection(bool cDir){
if(cDir){
if(oldsdir != cDir){
digitalWrite(PIN_DIR, 0);
sdir = true;
Serial.print("#################################### Carrage Direction: ####################################");
Serial.println(cDir);
oldsdir = cDir;
updateLcdDirection(cDir);
else
digitalWrite(PIN_DIR, 1);
sdir = false;
oldsdir = cDir;
ISR(TIMER1_COMPA_vect){
PORTF |= 1 << 0;
PORTF &= ~(1 << 0);
//##################################### LOOP #####################################
//##################################### Check Endstop Initiailisation #####################################
//if the unit has just been switched on then perform a calibration of the rail.
if(!calibratedSlider){
Calibrate();
}else{
//if the calibration has already been done then
MainLoop();
//calibrate the slider for MAXSlide.
void Calibrate()
//if the carrage hasnt been homed then home it.
if(!carrageHomed){
HomeCarrage();
}else{
if(calibrationStep == 0)
Serial.println("calibration step 1 complete");
calibrationStep = 1;
if(calibrationStep == 1){
//once the carrage is at home send it all the way to the other end of the rail.
if(MaxSlide == 0){
SeekEndStop();
}else{
Serial.println("calibration step 2 complete");
calibrationStep = 2;
if(calibrationStep == 2){
HomeCarrage();
}else{
Serial.println("calibration step 3 complete");
calibrationStep = 3;
calibratedSlider = true;
carrageDirection(true);
void SeekEndStop(){
//rest the stall value
//IM - only run this part the first time we start this process.
if(!TMC2130enabled)
Serial.println("########### SeekEndStop ###########");
resetStallSleep();
enableTMC2130();
static int cal_last_time = checkInerval;
int StallVal;
//set the carrage direction toward home
if((cal_last_time--) == 0)//IM - dont run every loop the stepper driver wont like it!
//Serial.println("Calibration Mode");
uint32_t drv_status = driver.DRV_STATUS();
StallVal = (drv_status & SG_RESULT_bm)>>SG_RESULT_bp;
//Serial.println(StallVal);
if(!stallSleep){
if(StallVal == 0){
stall = true;
Serial.println("SeekEndStop: stall!");
if(stallSleep){
decrementStallSleep();
if(!stall){
digitalWrite(PIN_STEP, HIGH);
delayMicroseconds(100);
digitalWrite(PIN_STEP, LOW);
calSteps++;
}else{
if(TMC2130enabled){
stallSleep = true;
MaxSlide = calSteps;
CalcRailLength();
Serial.print(" ########### Max Slide Found: ");
Serial.print(MaxSlide);
Serial.println(" ########### ");
carragePos = MaxSlide; //as were at the end of the rail then set carrage pos to maxslide.
disableTMC2130();
//IM - Calculates the lenght of the rail based on the number of steps taken before it hit the end (MaxSlide),
//devided by the number of steps taken in one mm (a fixed value up top calculated for our stepper motor).
void CalcRailLength(){
//calculate the rail length in MM
RailLength = MaxSlide / StepsPerMM;
Serial.print(" ########### Rail Length: ");
Serial.print(RailLength);
//psudo timer, allows some clock cycles to happen to delay a redetection of a motor stall.
void decrementStallSleep(){
if(stallSleep){
Serial.print("Stall Sleep:");
Serial.println(stallSleepDuration);
stallSleepDuration-- ;
if(stallSleepDuration == 0){
Serial.println("STALL SLEEP END");
stallSleep = false;
//IM - if you know your not stalling out then you can reset the stall sleeper.
void resetStallSleep(){
stall = false;
stallSleep = false;
void HomeCarrage(){
if(!TMC2130enabled){
Serial.println("########### Home Carrage ###########");
enableTMC2130();
resetStallSleep();
Serial.print("Check Interval: ");
Serial.println(checkInerval);
Serial.print("Stall: ");
Serial.println(stall);
int StallVal;
carrageDirection(false);
//Serial.println("HomeCarrage: here");
if(!stallSleep){
if(StallVal == 0){
stall = true;
Serial.println("HomeCarrage: Stall!");
stallSleep = true;
if(stallSleep){
if(!stall){
}else{
stallSleep = true;
carrageHomed = true;
carragePos = 0; //IM - Where home!
if(TMC2130enabled){
Serial.println(" ########### Homed ############");
//disableTMC2130();
void StartStop(){
Serial.println("if button pressed");
//if the slider is running then enable or dissable the stepper.
if ((sspeed == 0) && (decimals == 0)) {
srunning = 0;
Serial.print("######### StartStop: STOPPED #########");
else {
Serial.print("######### StartStop: STARTED #########");
if(carrageHalted == true){
srunning = !srunning;
setPeriod();
updateLCDStatus();
void MainLoop(){
static uint32_t last_time=0;
uint32_t ms = millis();
//##################################### ENCODER AND BUTTON START #####################################
long newPosition = myEnc.read();
if ((newPosition < 0) && (newPosition < offset)) {
offset = newPosition;
newPosition = newPosition - offset;
//IM If the new position of the rotary encoder is different then..
if (newPosition != oldPosition) {
oldPosition = newPosition;
updateRuntime();
//Serial.println(newPosition);
//Serial.print("\n");
setPeriod();
//IM - If the interupt has been triggered by the button being pressed, buttonPressed will be true.
if (buttonPressed) {
StartStop();
//##################################### ENCODER AND BUTTON END #####################################
//##################################### TOUCH SCREEN START #####################################
// a point object holds x y and z coordinates
TSPoint p = ts.getPoint();
pinMode(XM, OUTPUT);
pinMode(YP, OUTPUT);
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
//if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
if (p.z > ts.pressureThreshhold) {
//IM - Map the touch screen relitive to it size
p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
//IM - Print the y position value
//Serial.print("X = "); Serial.print(p.x);
//Serial.print("\tY = "); Serial.print(p.y);
//a temporary variable to store the new direction
int DIR = 0;
//IM - If the new point os less than the mid value then its to the left.
//IM - Note: this depends on physical screen orientation! if it is upside down change < to >.
if (p.x < ts_MID) {
sdir = 0; //IM - Set the direction bit to 0
//IM - Write to the pin the direction value
DIR = 0;
//Serial.println("left");
else {
sdir = 1; //IM - Set the direction bit to 1
DIR = 1;
//Serial.println("right");
//IM - if its a new direction up date the desplay
carrageDirection(sdir);
if (sdir != oldsdir) {
updateLCDStatus();
//##################################### TOUCH SCREEN END #####################################
//##################################### BATTERY STATUS CHECK START #####################################
// if ((long)(millis() - nextBattMillis) >= 0) {
//update Battery status
// nextBattMillis += 10000;
// rawVolt = ((float)analogRead(PIN_BATTVOLT)) * 0.02 + rawVolt * 0.98;
// volt = toVolt(rawVolt);
// tft.setTextColor(WHITE);
// if (volt < 8) {
// tft.setTextColor(GREEN);
// if (volt < 7.2) {
// tft.setTextColor(YELLOW);
// if (volt < 6.5) {
// tft.setTextColor(RED);
// tft.fillRect(0, 110, 150, 22, BLACK);
// tft.setTextSize(1);
// tft.setCursor(0, 130);
// tft.setFont(&FreeSans12pt7b);
// tft.print(mapFloat(volt, 6, 8.4, 0, 100)); tft.print("% ");
// tft.print("volt"); tft.print("V ");
// tft.print("rawVolt"); tft.print("int ");
// Serial.print("Battery Check:"); Serial.print(volt); Serial.print("; "); Serial.println(millis());
//##################################### BATTERY STATUS CHECK END #####################################
void updateLcdDirection(bool d){
if (!d) {
tft.fillTriangle(
320, 200, // peak
280, 240, // bottom left
320, 240, // bottom right
BLACK);
tft.fillTriangle(
0, 200, // peak
40, 240, // bottom right
tft.color565(255, 0, 50));
else {
tft.fillTriangle(
0, 200, // peak
BLACK);
tft.fillTriangle(
320, 200, // peak
void updateLCDStatus() {
if (runtime < MINRUNTIME) {
if (!drawnStatusBlank) {
tft.fillRect(75, 200, 170, 35, BLACK);
srunning = 0;
drawnStatus = 0;
return;
else if (drawnStatusBlank || (drawnStatus != srunning)) {
tft.setTextSize(1);
tft.setCursor(0, 0);
tft.setFont(&FreeSans18pt7b);
if (srunning) {
tft.setCursor(75, 230);
tft.print("RUNNING");
else {
tft.setCursor(100, 230);
tft.setTextColor(BLUE);
tft.print("READY");
drawnStatusBlank = 0;
//IM Updates the runtime when the rotary encoder is turned.
void updateRuntime() {
if (oldPosition != 0) {
runtime = 1000 * oldPosition * oldPosition / 4;
if (needsInit) {
else {
updateLCDTime(false);
updateLCDStatus();
//IM Updates the LCD with the new run time
void updateLCDTime(boolean firstrun) {
int days = runtime / day ; //number of days
int hours = (runtime % day) / hour; //the remainder from days division (in milliseconds) divided by hours, this gives the full hours
int minutes = ((runtime % day) % hour) / minute ; //and so on...
int seconds = (((runtime % day) % hour) % minute) / second;
tft.setCursor(0, 20);
tft.setTextSize(4);
tft.setFont();
if (oldPosition == 0) {
tft.setCursor(42, 70);
tft.setFont(&FreeMonoBold24pt7b);
tft.setTextSize(2);
tft.fillRect(0, 5, 320, 28, BLACK); //clear time
tft.fillRect(0, 54, 320, 35, BLACK); // clear speed
tft.print("HALT");
srunning = false;
tft.setTextSize(1);
tft.setFont(&FreeMono18pt7b);
tft.setCursor(0, 100);
// tft.print("0 mm/s");
sspeed = 0;
decimals = 0;
needsInit = true;
else {
if (firstrun) {
tft.fillRect(42, 24, 230, 30, BLACK); //clear HALT/STOP
tft.setFont(&FreeMonoBold18pt7b);
tft.setTextSize(1);
//DAYS
if ((days != oldDays) || firstrun) {
tft.setCursor(0, 30);
tft.fillRect(0, 5, 42, 28, BLACK);
if (days < 10) {
tft.print("0");
tft.print(days);
oldDays = days;
//HOURS
if (firstrun) {
tft.print("d");
tft.setCursor(80, 30);
if ((hours != oldHours) || firstrun) {
tft.fillRect(80, 5, 42, 28, BLACK);
if (hours < 10) {
tft.print("0");
tft.print(hours);
oldHours = hours;
//MINUTES
if (firstrun) {
tft.print("h");
tft.setCursor(160, 30);
if ((minutes != oldMinutes) || firstrun) {
tft.fillRect(160, 5, 42, 28, BLACK);
if (minutes < 10) {
tft.print("0");
tft.print(minutes);
oldMinutes = minutes;
//SECONDS
if (firstrun) {
tft.print("m");
tft.setCursor(240, 30);
if ((seconds != oldSeconds) || firstrun) {
tft.fillRect(240, 5, 42, 28, BLACK);
if (seconds < 10) {
tft.print("0");
tft.print(seconds);
oldSeconds = seconds;
if (firstrun) {
tft.print("s");
needsInit = false;
if ((oldPosition + offset) != myEnc.read()) {
return;
tft.setCursor(0, 80);
tft.setTextSize(1);
//IM INTERESTING.speed = distance over time
//sspeed = (1000000) / (runtime);
sspeed = (RailLength*1000) / (runtime);
if (runtime < (MINRUNTIME * 2)) {
tft.print(sspeed);
tft.print(".");
decimals = ((1000000000) / (runtime)) - (((1000000) / (runtime)) * 1000);
//decimals = ((RailLength*1000000) / (runtime)) - (((RailLength*1000) / (runtime)) * 1000);
if (decimals < 100) {
if (decimals < 10) {
tft.print("0");
tft.print("0");
tft.print(decimals);
tft.print(" mm/s");
//########################### TIMER PERIOD ###############################
void setPeriod() {
Serial.println("########################### set period ########################### ");
if ((runtime < MINRUNTIME) | ! srunning) {
Serial.print("srunning: ");
Serial.println(srunning);
//disableTMC2130();
Timer1.stop();
Serial.print("setPeriod: Timer Stopped");
Serial.print("\n");
else {
//IM - TIMER CODE TO WORKOUT THE RUNNING TIME
enableTMC2130();
//calculate the speed in mm/s by deviding the rail lenght by the desired runtime in microseconds
float ssspeed = (RailLength*1000) / ((float) runtime);
float sps = ssspeed * (StepsPerMM);
float pperiod = (RailLength*1000) / sps;
Serial.print("RunTime: ");
Serial.println(runtime);
Serial.print("ssspeed: ");
Serial.println(ssspeed,7);
Serial.print("RailLength: ");
Serial.println(RailLength*1000);
Serial.print("sps: ");
Serial.println(sps,7);
pperiod = ((float)runtime)/((float)MaxSlide);
Serial.print("setPeriod: ");
Serial.println(pperiod);
Timer1.setPeriod(pperiod*500);
float toVolt(float rawADC) {
return mapFloat(rawADC, 0, 1023, 0, 10.8); //empirical calibration
float mapFloat(float x, float in_min, float in_max, float out_min, float out_max)
return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
float lookup(float inval, short lut[][2], short clamp){
float out;
byte i;
for (i=1; i<LOOKUP; i++)
if (lut[i][0] > inval)
return lut[i-1][1] + (inval - lut[i-1][0]) * (lut[i][1] - lut[i-1][1]) / (lut[i][0] - lut[i-1][0]);
if (i == LOOKUP){
return clamp;
