I see several posts stating that only qos=0 is supported for publishing and only qos=0 & qos=1 are supported for subscribing. Is this still true?
When I subscribe to an Adafruit IO feed with qos=2 it does not throw an error. Also, when the onsubscribe method fires it returns a granted_qos parameter of 2.
Status of QOS
- jwcooper
Re: Status of QOS
IO supports qos 0 and 1, but not 2.
- rdagger
Re: Status of QOS
I suggest the granted_qos parameter should return the correct value or an unsupported error should be raised.
- jwcooper
Re: Status of QOS
What MQTT client library are you using?
- rdagger
