ESP32-V2 No Data for a month
- DJDevon3
I updated around mid october and it broke something and stopped receiving data. I just left it since I couldn't get it working. Updated to beta .54 tonight. Using the ESP32-V2 with DPS310 & MCP9808 sensors. Deleted all sensors, feeds, and dashboard. Created a new dashboard, added both sensors, created line chart blocks in F, same thing. Feeds receive no data. Board says it's Online.
- mikeysklar
Re: ESP32-V2 No Data for a month
Can you post what you are seeing on the serial monitor?
- DJDevon3
Oops should have specified this is on wippersnapper. Sorry thought I posted in a wippersnapper topic. There is no serial in wippersnapper to my knowledge.
- mikeysklar
What OS are you running on your PC? You should still have a serial device that you can connect to through screen, putty or the Arduino IDE console.
- brubell
- Learn User Page
WipperSnapper does have serial output if you use one of the options posted above.Feeds receive no data. Board says it's Online.
what color is the board's LED when it turns on? Could you post a screenshot of the device page on Adafruit IO? What firmware version is the device?
- DJDevon3
Blinks yellow 5 times
Blinks blue 5 times
Blinks purple 5 times
Short green pulse
Attached I2C devices have green LED's indicating power.
Just looked in my new dashboard (days later) and it started magically logging again on Nov 10th. Everything looks good again.
I got so frustrated with Arduino that I uninstalled it months ago. Been on circuit python for everything else except this V2 on wippersnapper. WipperSnapper makes it so easy that I don't even have to use Arduino anymore.
Blinks blue 5 times
Short green pulse
- brubell
- Learn User Page
I'm going to set up a long-term soak test to track this issue. Could you provide a screenshot of your device's page on Adafruit IO showing the components and board name?Just looked in my new dashboard (days later) and it started magically logging again on Nov 10th. Everything looks good again.
