Can the audio fx boards mount into the feather screw terminal board?
The audio fx boards appear to be the same size as the feather boards
Screw terminal breakout board
Re: Screw terminal breakout board
The space between the FX Board's pins is the same as the pin spacing on the Feather: 0.8" at 0.1" pitch, but the boards have different numbers of pins: the FX Board has 14 pins on each side. The Feather has 16 pins on one side and 12 pins on the other side.
