MCP9601 cannot use 0x60 I2C address
- rhchiu
According to the MCP960x datasheet, figure 6-4, to get 0x60 I2C address, connect the ADDR pin directly to GND. When I connect ADDR to the ground, my Arduino 33 IoT cannot find the device. I can get the other 7 I2C addresses by using different resisters to connect ADDR and GROUND. I like to connect 8 thermocouples to a single Arduino device. Please help. Thanks Richard
- adafruit_support_carter
Re: MCP9601 cannot use 0x60 I2C address
What addresses show up in an I2C scan without the MCP9601 attached?
https://learn.adafruit.com/scanning-i2c ... ng-testbed
- rhchiu
That scanner worked as promised. Thank you. But it find two extra I2C devices. Those two I2C device's addresses are 0x60 and 0x6A. Even when I disconnect all MCP9601 from the I2C bus, the scanner still found two devices. Looks like this extra device at 0x60 is preventing MCP9601 from using 0x60 as I2C address. I wonder if this is Arduino 33 Iots problem. Anyone have similar problem ??
- rhchiu
I found the answer in the Arduino Forum.
https://forum.arduino.cc/t/tca9548a-fin ... 1041639/10
0x60 and 0x6A are used by Arduino 33 IOT.
- Franklin97355
Thank you for posting your discovery. It will help someone.
