Sure, I used the example and the changes were setting the pins for my wiring and added some print statements.
In the serial monitor, I turned on the timestamps - just in case you weren't sure where that came from. It's not in the code.
This happens in the project I'm working on as well.
This is our touchscreen painting example for the Adafruit ILI9341 Breakout
----> http://www.adafruit.com/products/1770
Check out the links above for our tutorials and wiring diagrams
These displays use SPI to communicate, 4 or 5 pins are required to
interface (RST is optional)
products from Adafruit!
MIT license, all text above must be included in any redistribution
/** NOT FOR USE WITH THE TOUCH SHIELD, ONLY FOR THE BREAKOUT! **/
#include <Adafruit_GFX.h> // Core graphics library
#include <SPI.h>
#include <Adafruit_ILI9341.h>
#include "TouchScreen.h"
// These are the four touchscreen analog pins
#define YP A2
#define XM A3
#define YM 10
#define XP 11
// also MISO/MOSI/SCK
#define TFT_CS 13
#define TFT_DC 12
// This is calibration data for the raw touch data to the screen coordinates
#define TS_MINX 150
#define TS_MINY 120
#define TS_MAXX 920
#define TS_MAXY 940
#define MINPRESSURE 10
#define MAXPRESSURE 1000
// The display uses hardware SPI, plus #9 & #10
// #define TFT_CS 10
// #define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// Size of the color selection boxes and the paintbrush size
#define BOXSIZE 40
#define BANNED 3
int oldcolor, currentcolor;
void setup(void) {
// while (!Serial); // used for leonardo debugging
Serial.println(F("Touch Paint!"));
tft.begin();
tft.fillScreen(ILI9341_BLACK);
// make the color selection boxes
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_RED);
tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_YELLOW);
tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_GREEN);
tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_CYAN);
tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_BLUE);
tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_MAGENTA);
// select the current color 'red'
tft.drawRect(0, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
currentcolor = ILI9341_RED;
void loop()
// Retrieve a point
TSPoint p = ts.getPoint();
Serial.print("X = "); Serial.print(p.x);
Serial.print("\tY = "); Serial.print(p.y);
Serial.print("\tPressure = "); Serial.println(p.z);
// we have some minimum pressure we consider 'valid'
// pressure of 0 means no pressing!
if (p.z < MINPRESSURE || p.z > MAXPRESSURE) {
return;
// Scale from ~0->1000 to tft.width using the calibration #'s
p.x = map(p.x, TS_MINX, TS_MAXX, 0, tft.width());
p.y = map(p.y, TS_MINY, TS_MAXY, 0, tft.height());
Serial.print(millis());
Serial.print(", "); Serial.print(p.x);
Serial.print(", "); Serial.print(p.y);
Serial.print(", "); Serial.println(p.z);
if (p.y < BOXSIZE) {
oldcolor = currentcolor;
if (p.x < BOXSIZE) {
} else if (p.x < BOXSIZE*2) {
currentcolor = ILI9341_YELLOW;
tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE*3) {
currentcolor = ILI9341_GREEN;
tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE*4) {
currentcolor = ILI9341_CYAN;
tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE*5) {
currentcolor = ILI9341_BLUE;
tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
} else if (p.x < BOXSIZE*6) {
currentcolor = ILI9341_MAGENTA;
tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9341_WHITE);
if (oldcolor != currentcolor) {
if (oldcolor == ILI9341_RED)
if (oldcolor == ILI9341_YELLOW)
if (oldcolor == ILI9341_GREEN)
if (oldcolor == ILI9341_CYAN)
if (oldcolor == ILI9341_BLUE)
if (oldcolor == ILI9341_MAGENTA)
if (((p.y-BANNED) > BOXSIZE) && ((p.y+BANNED) < tft.height())) {
tft.fillCircle(p.x, p.y, BANNED, currentcolor);
Output after single point touch on fresh start, and then subsequent 'phantom' touches :
08:20:20.581 -> 171481, -46, 352, 598
08:20:20.671 -> 171571, -46, 352, 598
08:20:21.008 -> 171922, 68, 182, 614
08:20:21.008 -> 171923, 70, 181, 593
08:20:21.008 -> 171925, 69, 182, 453
08:20:21.008 -> 171926, 71, 184, 338
08:20:21.008 -> 171927, 69, 184, 317
08:20:21.008 -> 171929, 70, 183, 301
08:20:21.008 -> 171930, 71, 182, 323
08:20:21.008 -> 171931, 72, 182, 275
08:20:21.040 -> 171933, 72, 181, 276
08:20:21.040 -> 171934, 72, 181, 274
08:20:21.040 -> 171935, 73, 182, 262
08:20:21.040 -> 171936, 73, 181, 256
08:20:21.040 -> 171938, 74, 181, 250
08:20:21.040 -> 171938, 74, 181, 253
08:20:21.040 -> 171939, 73, 181, 252
08:20:21.040 -> 171940, 73, 181, 254
08:20:21.040 -> 171941, 74, 181, 250
08:20:21.040 -> 171943, 74, 181, 242
08:20:21.040 -> 171944, 72, 180, 234
08:20:21.040 -> 171945, 73, 180, 229
08:20:21.040 -> 171946, 73, 180, 222
08:20:21.040 -> 171947, 73, 180, 223
08:20:21.040 -> 171948, 73, 180, 221
08:20:21.040 -> 171949, 74, 181, 224
08:20:21.040 -> 171950, 74, 180, 241
08:20:21.040 -> 171951, 73, 180, 247
08:20:21.040 -> 171952, 74, 180, 281
08:20:21.040 -> 171953, 73, 181, 272
08:20:21.040 -> 171955, 72, 181, 308
08:20:21.040 -> 171956, 73, 181, 345
08:20:21.040 -> 171958, 71, 183, 411
08:20:21.040 -> 171959, 71, 181, 541
08:20:21.040 -> 171960, 70, 181, 719
08:20:21.040 -> 171962, 71, 181, 692
08:20:21.087 -> 171965, 71, 182, 610
08:20:21.087 -> 171966, 71, 182, 626
08:20:21.087 -> 171967, 70, 181, 741
08:20:21.087 -> 171968, 69, 182, 923
08:20:23.626 -> 174503, -46, 352, 299
08:20:25.810 -> 176700, -46, 352, 299
08:20:25.902 -> 176784, -46, 352, 299
08:20:28.531 -> 179418, -46, 352, 598
08:20:31.487 -> 182397, -46, 298, 598
08:20:34.011 -> 184894, -46, 352, 598
08:20:37.486 -> 188399, -46, 352, 598
08:20:40.364 -> 191253, -46, 297, 299
08:20:40.807 -> 191698, -46, 298, 299
08:20:41.688 -> 192585, -46, 298, 299
08:20:44.851 -> 195737, -46, 352, 598
08:20:46.062 -> 196947, -46, 352, 598
08:20:48.180 -> 199075, -46, 352, 598
08:20:48.788 -> 199678, -46, 298, 598
08:20:49.280 -> 200173, -46, 352, 299
08:20:50.136 -> 201052, -46, 352, 299
08:20:50.960 -> 201863, -46, 352, 598
08:20:51.178 -> 202079, -46, 352, 299
08:20:51.678 -> 202600, -46, 352, 299
08:20:52.304 -> 203218, -46, 352, 299
08:21:02.750 -> 213642, -46, 352, 598
08:21:05.361 -> 216250, -46, 352, 598
08:21:10.795 -> 221708, -46, 297, 598
08:21:12.181 -> 223094, -46, 352, 299
08:21:17.369 -> 228266, -46, 352, 299
08:21:21.452 -> 232345, -46, 352, 598
08:21:22.197 -> 233100, -46, 352, 299
08:21:25.055 -> 235962, -46, 352, 598
08:21:26.739 -> 237649, -46, 352, 598
08:21:28.961 -> 239851, -46, 352, 598
08:21:29.133 -> 240053, -46, 352, 598
08:21:29.584 -> 240468, -46, 352, 299
08:21:30.140 -> 241049, -46, 298, 299
08:21:33.071 -> 243965, -46, 352, 598
08:21:33.982 -> 244887, -46, 352, 598
08:21:36.044 -> 246957, -46, 352, 299
08:21:39.392 -> 250273, -46, 352, 598
08:21:41.186 -> 252086, -46, 299, 299
08:21:42.616 -> 253494, -46, 352, 299
08:21:56.732 -> 267640, -46, 352, 299
08:21:58.808 -> 269701, -46, 298, 299
08:22:01.947 -> 272829, -46, 352, 598
08:22:04.360 -> 275244, -46, 352, 299
08:22:04.501 -> 275398, -46, 352, 299
08:22:07.947 -> 278853, -46, 352, 597
08:22:09.316 -> 280207, -46, 352, 598
08:22:10.689 -> 281568, -46, 352, 598
08:22:15.870 -> 286749, -46, 298, 299
08:22:16.949 -> 287830, -46, 352, 299
08:22:22.131 -> 293013, -46, 352, 598
08:22:22.662 -> 293544, -46, 352, 598
08:22:23.421 -> 294314, -46, 352, 598
08:22:23.686 -> 294573, -46, 352, 598
08:22:25.458 -> 296342, -46, 352, 598
08:22:33.823 -> 304706, -46, 298, 299
08:22:38.225 -> 309109, -46, 352, 598
08:22:39.629 -> 310542, -46, 352, 299
08:22:44.321 -> 315208, -46, 298, 299
08:22:44.964 -> 315866, -46, 352, 598
08:22:45.961 -> 316865, -46, 352, 598
08:22:50.349 -> 321236, -46, 352, 299
08:22:56.107 -> 327017, -46, 352, 598
08:22:57.189 -> 328093, -46, 352, 598
08:23:02.390 -> 333284, -46, 352, 299
08:23:02.514 -> 333436, -46, 352, 299
08:23:04.193 -> 335096, -46, 352, 299
08:23:04.445 -> 335343, -46, 352, 299
08:23:05.670 -> 336562, -46, 352, 598
08:23:06.812 -> 337700, -46, 352, 299
08:23:08.402 -> 339288, -46, 352, 598
08:23:10.690 -> 341583, -46, 352, 598
08:23:13.802 -> 344697, -46, 352, 598
08:23:15.253 -> 346142, -46, 298, 299
08:23:16.452 -> 347344, -46, 352, 598
08:23:20.010 -> 350913, -46, 298, 598
08:23:24.086 -> 354970, -46, 352, 299
08:23:24.337 -> 355221, -46, 352, 299
08:23:27.326 -> 358251, -46, 352, 598
08:23:29.341 -> 360232, -46, 352, 299
08:23:36.493 -> 367380, -46, 352, 299
08:23:40.994 -> 371892, -46, 352, 598
08:23:46.343 -> 377228, -46, 298, 299
08:23:51.597 -> 382494, -46, 352, 598
08:23:54.528 -> 385431, -46, 352, 598
08:23:56.444 -> 387347, -46, 352, 299
08:23:57.130 -> 388021, -46, 352, 299
08:24:02.324 -> 393211, -46, 352, 299
08:24:02.470 -> 393362, -46, 352, 299
08:24:03.987 -> 394874, -46, 352, 299
08:24:10.386 -> 401280, -46, 352, 298
08:24:14.464 -> 405368, -46, 352, 299
08:24:14.759 -> 405665, -46, 352, 299
08:24:21.759 -> 412665, -46, 352, 299
08:24:23.965 -> 414877, -46, 352, 598
08:24:26.199 -> 417101, -46, 352, 299
08:24:30.217 -> 421138, -46, 352, 299
08:24:31.300 -> 422183, -46, 352, 299
08:24:34.138 -> 425036, -46, 352, 598
08:24:34.836 -> 425717, -46, 352, 299
08:24:36.152 -> 427049, -46, 352, 598
08:24:37.116 -> 428018, -46, 299, 598
08:24:41.622 -> 432529, -46, 352, 598
08:24:46.724 -> 437613, -46, 298, 299
08:24:52.201 -> 443090, -46, 352, 598
08:24:53.982 -> 444870, -46, 352, 598
08:24:56.087 -> 446992, -46, 352, 299
08:24:58.674 -> 449554, -46, 298, 598
08:25:03.716 -> 454616, -46, 352, 299
08:25:04.747 -> 455627, -46, 298, 299
08:25:08.868 -> 459751, -46, 352, 299
08:25:11.864 -> 462788, -46, 352, 299
08:25:13.821 -> 464736, -46, 352, 299
08:25:16.233 -> 467124, -46, 352, 299
08:25:17.699 -> 468587, -46, 352, 598
08:25:18.051 -> 468941, -46, 352, 598
08:25:19.217 -> 470103, -46, 352, 299
08:25:20.515 -> 471426, -46, 352, 598
08:25:20.639 -> 471531, -46, 352, 598
08:25:24.269 -> 475173, -46, 297, 299
08:25:25.813 -> 476720, -46, 352, 299
08:25:26.956 -> 477841, -46, 352, 299
08:25:29.318 -> 480215, -46, 298, 299
08:25:29.393 -> 480298, -46, 352, 299
08:25:31.636 -> 482530, -46, 352, 598
08:25:34.454 -> 485358, -46, 352, 299
08:25:38.622 -> 489517, -46, 352, 299
08:25:40.828 -> 491717, -46, 352, 598
08:25:42.021 -> 492912, -46, 352, 598
08:25:42.840 -> 493734, -46, 352, 596
08:25:46.444 -> 497330, -46, 352, 299
08:25:49.565 -> 500457, -46, 297, 598
08:25:50.402 -> 501312, -46, 352, 299
08:25:52.083 -> 502977, -46, 352, 299
08:25:53.075 -> 503955, -46, 352, 598
08:25:58.018 -> 508907, -46, 352, 299
08:25:58.250 -> 509136, -46, 352, 598
08:25:59.993 -> 510907, -46, 352, 598
08:26:01.927 -> 512816, -46, 352, 598
08:26:02.206 -> 513094, -46, 298, 598
08:26:07.168 -> 518062, -46, 352, 299
08:26:09.207 -> 520101, -46, 352, 299
